Old 07-08-2011, 10:14 PM
SVXx2's Avatar
SVXx2 SVXx2 is offline
...and the drivers window went POP
So I'm in the car, and decide to roll up the windows and turn on the A/C. All of a sudden, I hear a loud POP and the tinkling of glass. All windows are up, but when I try to operate the drivers window, I hear the motor, but the window doesn't move. Did the glass come off of the rails, and then get broken down in the door? If so, ideas for fixes?
Old 07-08-2011, 10:28 PM
Re: ...and the drivers window went POP
The window bracket probably detached from the cable. There is a small white plastic clip thingy in there that attaches them. Sometimes they break. The good news is that you can probably fix it for a lot cheaper than you were probably thinking when you posted this.
Old 07-08-2011, 11:40 PM
BRADY's Avatar
BRADY BRADY is offline
SVX Addict
Send a message via MSN to BRADY Send a message via Skype™ to BRADY
Do a SEARCH for 'sleeve lock regulator'.
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com
Old 07-09-2011, 08:31 AM
Sleeve Lock Regulator. Complete replacement Instructions with photos
P/N 62101PA081 about $7.88 each. Buy a couple.
Old 07-09-2011, 09:44 AM
8 years ago mine broke. I went to Subaru and they said it is a whole kit 40 bucks . I had a guy in work make me one on a CNC machine out of nylon. I figure it cost the company 100 bucks .( programing, time and material ). I should have made a dozen for an extra $5.00 it would have cost . ooops . i don't feel bad the Company left town and left us High and dry 1,200 people out of work
Old 07-09-2011, 01:57 PM
The Molinator
P/N 62101PA081 about $7.50 each. Buy a couple.
I keep one in my back pocket!
Jim
