Old 06-08-2011, 11:49 AM
Awox Awox is offline
A/C compressor not engaging.
Is there anything other than a blown fuse or relay that would prevent the A/C from turning on?...it appears my compressor is not engaging. Fans and other climate controls work fine but the ac does not. Will low pressure in refrigerator lines cause this? I don't wanna spend 30 bucks on a recharge if I don't have to..
Old 06-08-2011, 12:13 PM
kwren's Avatar
kwren kwren is offline
Re: A/C compressor not engaging.
It will...
It is a safety feature to keep the compressor from sucking moist air and other contaminants in the system if a leak develops and the refrigerant is lost.
Keith
processengr's Avatar
Low pressure will cause compressor not to engage due to low pressure cutout switch. You will want to recharge with a dye for finding leaks, if this is the case...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 06-20-2011, 02:59 PM
SVXx2's Avatar
SVXx2 SVXx2 is offline
I just had a similar problem with my '96 SVX. The cause was a rear seal on the compressor had failed, and the refrgerant had leaked out. Couldn't even turn the compressor by hand with the engine shut off.
Old 06-21-2011, 09:31 AM
alia176 alia176 is offline
forgive this dumb question but would the Climate control diagnostic module tell you what the problem is?
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 06-21-2011, 11:02 AM
Maybe, it depends what the problem is??? It won't give an error for high or low pressure in the system.
Old 06-21-2011, 11:15 AM
When I tried pulling codes on my '97 when I knew the refrigerant pressure was too low because it had leaked out, it didn't show any codes. 2 O-rings and a recharge and it was all fixed.
