Old 01-25-2011, 05:26 AM
Cam Cam is offline
Engine installation
Ok, so I got the engine in most of the way. All four bellhousing bolts/nuts are started. But...
I am having trouble getting the studs on the bottom of the engine mount bushings to clear the crossmember. I started to drop the crossmember but after loosening the 12 bolts (3 in each corner of the crossmember) I still couldn't get it to budge. Are there more bolts? Am I taking the wrong approach to this?
If anyone has some wisdom to pass along I am all ears.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 01-25-2011, 05:51 AM
StatGSR StatGSR is offline
Send a message via AIM to StatGSR
Re: Engine installation
Did you jack up the front of the transmission as much as possible? you shouldn't have to loosen the cross member to get the engine back in.
94 Acura Integra GSR
97 Legacy Brighton - EG33 Swap still in progress
03 Silverado 2500 - Duramax
Old 01-25-2011, 05:58 AM
Cam Cam is offline
I did jack the transmission up as much as I could. But maybe I will try more...tomorrow, anyways. Are there some bolts I should take out of the transmission?
Cam
'92 Ls-L Dark Teal
Old 01-25-2011, 06:40 AM
disconnect the dog bone mount on the top of it.
Old 01-25-2011, 02:50 PM
immortal_suby's Avatar
Thread Killah
I thought I remembered dropping the rear of the transmission to let it tilt up. Been a while though.
Locker Link
2015 BRZ Limited 6MT
Old 01-25-2011, 03:17 PM
I've always just removed the dogbone and jacked up the front of the trans.
Old 01-25-2011, 08:24 PM
Cam Cam is offline
The dogbone was enough. allowed the tranny to mate up quite nicely. Engine is in and I am about to try to start it very soon...
Cam
'92 Ls-L Dark Teal
Old 01-25-2011, 09:35 PM
Make sure you have a video camera handy.
Old 01-25-2011, 09:50 PM
Cam Cam is offline
I'm glad I didn't catch that on video! haha.
She started, sounded amazing, but then I lost some front seals...no idea how that happened. Losing quite a bit of oil from the front of the engine...what can you do....
My bet is the front main seal. Maybe I can salvage it? I don't know how it would have come out though...
Was hoping I would be able to listen to her for more than 10 seconds....
Oh well, at least she started
Cam
'92 Ls-L Dark Teal
