Old 11-29-2010, 11:30 AM
Anyone ever dismantled the throttle body?
On a scale of 1-to-nightmare, how bad of an idea is this? I have it sitting on the desk beside me, IACV and brackets removed and am looking at the throttle linkage. There are about 235 springs in the thing, all hooked to different bars and notches...
I want to clean it up and have it anodized gold to match the new intake flanges I'll be cutting on the CNC mill, but that requires removal of everything not aluminum (vacuum line fittings excepted).
Old 11-30-2010, 09:54 PM
Re: Anyone ever dismantled the throttle body?
Anyone? I'm thinking it's doable, just tricky. Something like taking apart a Rolex.
Old 11-30-2010, 11:47 PM
Cam Cam is offline
I think the Rolex analogy is a stretch . However, take many close-up pics of springs, mark everything you can, and just dont rush anything. You should be fine.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 12-01-2010, 10:34 AM
laserx's Avatar
laserx laserx is offline
Taking it apart will be a breeze...it's putting back together that will be the challenge. Take lots of pictures as you go along...or do a video you can use as a reference it you get lost or stuck. Good luck.
1996 Black, 134,000 KM, with Custom Stainless from Headers to Stebro, 17" Wheels, Michelin Pilot Sport PS2 225/45/17 Cold Air Intake.
Pioneer AVIC D3 GPS/Video/Sound/Sirius/Bluetooth/USB
Koni struts/ground control coilovers
Stainless steel brake lines
K&N filter, custom front grill
H.I.D low beams 5000k 35w, H.I.D fog/driving 4500k 35w
Clear front and corner lens
Old 12-03-2010, 09:52 PM
Well I've got it 95% apart. Want to see some engineering insanity?
There are 42 pieces there, and a number of those could be broken down further. The only things left in the body itself are a little adjustable stop and the shaft that the butterflies slot into. I can't figure out how to remove that shaft without using more force than I'm comfortable with... One each side there are steel cap plates and you can see that one was installed and then the aluminum was dimpled around it to keep it in place.
Old 12-03-2010, 10:36 PM
httrdd httrdd is offline
Holy **** dude! That is a lot of pieces to out back together. GL!
