Old 10-12-2010, 06:01 PM
Manarius's Avatar
Manarius Manarius is offline
Remove and Replace Injectors
So, I'm trying to remove and replace the injectors in my car. Here are my questions at this point:
  • Is there an easy way of getting these things out? I fought with ones that I have...had to use needle nose pliers and I don't really like that method.
  • Which O-Ring should I replace?
-Jason
-Obi Wan Kenobi
Old 10-12-2010, 07:09 PM
immortal_suby's Avatar
Thread Killah
Re: Remove and Replace Injectors
I've had good luck turning them 90 degrees then using a large flat blade screwdriver or pry bar to pry up on the underside of the plastic part you plug the wiring into. Haven't broken one yet.
I imagine you'd want to replace both o-rings. I ordered a "kit" from autopartswarehouse to replace the o-rings, thinking it was for all 6. All I got was enough to do 1 injector. I still need to find a supplier and pull all of mine and replace the o-rings. The kit came with 4 o-rings. 2 fit the injector, I think the other 2 might be for the fuel rail.
Locker Link
2015 BRZ Limited 6MT
Old 10-12-2010, 09:15 PM
Manarius's Avatar
I got a multi-o-ring kit from Autozone; we'll see how many of those fit.
Another question: What do you do if one of those little screws strips out?
-Jason
-Obi Wan Kenobi
Old 10-12-2010, 09:26 PM
NO!
If you do not use Genuine Subaru injector O-Rings, and they leak, or fail altogether then you have gasoline squirting into your intake manifold at 36.3 PSI!
Can you say diluted oil, junk engine?
Also use plenty of petrolium jelly to lube up the new Subaru O-Rings so they do not get scuffed.
[SIZE="1"]Sorry for the size 7, and the RED but, an SVX engine deserves to live.[SIZE]
Old 10-13-2010, 07:30 AM
Manarius's Avatar
NO!
So, what is the part number for these things?
-Jason
-Obi Wan Kenobi
Old 10-13-2010, 07:58 AM
6- #16698AA050 Pt190294 O-ring $7.73
6- #16698AA060 Pt190294 O-ring $7.73
Thanks for listening.
Old 10-13-2010, 09:23 AM
Manarius's Avatar
$5.66 actually
and I certainly hope that's for 6 of them. Not just one. I'm not paying $60 for just gaskets.
-Jason
-Obi Wan Kenobi
Old 10-13-2010, 12:11 PM
$5.66 actually
The prices have been constantly "changing" at Subaru.
So I just showed the subaruparts.com list price without shipping.
And yes, they are $6.00 each times twelve, about $72.00.
Still much cheaper than an engine change.
Old 10-13-2010, 01:23 PM
Cam Cam is offline
When removing those tiny little screws it is essential you use an impact driver. It's a screwdriver that you hit with a hammer, and the internals force it to turn when being compressed. If you don't use one, you WILL strip out at least one screw (if you are uber lucky)
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-13-2010, 06:59 PM
Thread Killah
I tried that. None of them fit. Not one. The part listed to fit the svx at autozone and advance auto is wrong.
Locker Link
Old 10-13-2010, 08:48 PM
Green1995SVX's Avatar
It's a good thing you don't own a European car.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-13-2010, 09:07 PM
Manarius's Avatar
I have a guy down at Federated Auto who can get me o-ring kit sets for about $7 a piece. The Legacy 2.2 from 1995 takes the same gaskets, so it makes them a little easier to find. (Finding parts for the SVX is pretty much impossible, but when you search under Legacy, even though it's the same part number, they're available).
Hmm, if you search for the Legacy or SVX L, they have the kits for $3.52/injector on RockAuto. Heck, the injectors for the SVX are the same part number as the ones for the Legacy 2.2.
-Jason
-Obi Wan Kenobi
Old 10-13-2010, 09:29 PM
Yep, they both use the Red Tops.
Are you saying he can get six O-Rings for $7.00?!
Or for $7.00 each?
Old 10-13-2010, 09:40 PM
Rock auto uses a lot of the same suppliers that Autozone, advance auto and others all use as well as some things being OEM. so I wouldn't trust them from their either if the ones from AZ aren't good.
Old 10-14-2010, 12:51 AM
Gamesy's Avatar
Gamesy Gamesy is offline
holy crap those are pricy
FYI
the svx injectors use the same o-rings as the Nissan KA and SR engines(hence the sr-20det injectors for the ecutune stage2 setup),
i picked up all 12 gaskets from a local nissan dealer and i think it came to something like $15-18 for all of em
i did use needle nose pliers to take em off or just cut em. putting them back on was way easier make sure to lube em first, i let mine soak in oil.
as for taking them out of the rail..... ya.. it was easier to take the rail off and then took a hammer with a robertson to knock em out. the funny thing is those injectors still work properly after smacking it with a hammer and screwdriver. i do recommend replacing the phillips screws with hexkey screws in case they need to be changed later on.
these are my 2 cents... take it or leave it
