Old 07-03-2010, 12:56 AM
Chip Hutchinson Chip Hutchinson is offline
Front hub nut torque spec?
Hi guys. I am replacing the passenger side front hub assy. When I removed the nut
on the end of the CV shaft where it is attached to the hub, I noticed it is loose. What should it be torqued to?
TIA
Old 07-03-2010, 02:46 AM
Re: Front hub nut torque spec?
123-152 ft/lb.
Old 07-03-2010, 06:46 AM
I needed that info too.
Old 07-03-2010, 08:54 AM
Yup, 123-152 ft/lb. is what the Front Axle Replacement (42663).pdf says.
Attached:
HOW TO - Front Axle Replacement (42663).pdf
File Type: pdf HOW TO - Front Axle Replacement (42663).pdf (18.3 KB, 196 views)
Old 07-04-2010, 03:19 PM
Thanks You. I was concerned when I found it loose. Now I am wondering if that was the problem.
