5 horn beeps
So just out of the blue my horn beeps really fast for what I think is 5 times. This occurs during either lock/unlock. The alarm still seems to function properly and locks/unlocks the doors. According to my owners manual "use of non-authorized transmitter". Uh... its the original one (lost the 2nd one). So what do I need to do?
Re: 5 horn beeps
mine did that. it worked just the same so I said so what.
Matt 15 OBW premium w/eyesight A picture of an SVX in the garage |
Re: 5 horn beeps
Mine does too. I thought it was normal.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) |
Re: 5 horn beeps
Push your "Security Button" and turn your alarm back on.
1991 SVX L JDM |
Re: 5 horn beeps
+1 that sounds like what mine does when it's turned off.
Re: 5 horn beeps
Key on or key off? If I do it with ign "ON" and then remove the key, the security light will flash but the key fob becomes INOP. Do the process with the key off seems to have no effect.
Re: 5 horn beeps
Nevermind I figured it out.
Ign on engine running press security button turn ign off security light will flash quickly open door/close door hit the button on the remote and its back to normal. |
Re: 5 horn beeps
Ignition does not need to on be or engine running to switch between security and regular mode. The button is just a little tricky sometimes. I find a slower push where I hold it at full in for a split second, rather than just a quick push, seems to work.
Re: 5 horn beeps
Yea my button acts funny too. I think it's because of the rarity of use.
Re: 5 horn beeps
Question for you, when it was doing that did the lights flash? or no flash.
My son hit the security button today I didnt know it and tonight when i hit the remote I got that same thing, locking doors many quick beeps but no flashing lights, I looked on here to see if there was anything, which im glad there was went out looked sure enough no flashing security light, hit the button flashing normal and hit the remote and chirp with flashing parking lights. I think the other mode is just remote door locks no alarm. |
Re: 5 horn beeps
You are correct sir. In this mode the light will not flash.
