Old 06-09-2009, 07:41 PM
redlightningsvx's Avatar
Collision Refinishing Tech
What size tire?
What tire would be best for this rim on the stock suspension so I don't rub?
Info here.
http://www.discounttiredirect.com/di...w=7&vid=006494
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 06-09-2009, 08:55 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: What size tire?
225/45/17 would fit nicely, retaining stock diameter.
Old 06-09-2009, 09:41 PM
svxash's Avatar
svxash svxash is offline
Re: What size tire?
I'm running 225/45-17's on my ADR 17x7 48mm offset wheels.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 06-10-2009, 04:19 PM
Re: What size tire?
Thanks................
Seth
Past subies:
Other toys:
Old 11-22-2010, 02:24 PM
kcbsvx's Avatar
kcbsvx kcbsvx is offline
Now down to only ONE!
Re: What size tire?
Will 225 60 16 tires rub? I have some all season take-offs from my outback that I would like to mount on my SVX winter rims until I can afford a new set of winter shoes for the SVX.
Thanks,
Christian
Christian-
96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC.
2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock
1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods
2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock
Old 11-22-2010, 02:43 PM
Re: What size tire?
It will be close. On SVX rims you're asking? it might rub on the plastic fender "mud guard" or whatever it's called but won't rub on anything else. And even so, unless you have 200+lbs in the trunk or go over big bumbs, it still might not rub at all.. Might as well give it a shot and see, or at least that's what I would do.
Old 11-23-2010, 09:50 AM
kcbsvx's Avatar
Re: What size tire?
Thanks, Nate. They are aftermarket 5 spokes with close to factory offsets. I will try it since my summer rims/tires have ZERO snow traction as I learned a few years back when I was caught by surprise by 3/4 " of snow.
Christian-
Old 12-29-2010, 09:08 AM
TheRealStig TheRealStig is offline
Re: What size tire?
I bought a set of 17" alloys from an RX7 with ET of 50 mm.
I am planning to fit 235/45 Y17 on them. Will this combination fit?
It should be 5 mm wider inside and 15 mm outside. Diameter is the same as original.
Any reccommandation regarding tyre brand/type?
Old 12-29-2010, 12:46 PM
Re: What size tire?
Should be just peachy. What kind of tire are you looking for? Ultimate grip, touring, etc?
Old 12-29-2010, 01:26 PM
Re: What size tire?
The SVX is my daily driver. For excessive fun I have a Lotus Turbo Esprit.
I think I am looking for a set of tires, that gives neutral/direct steering, with good braking and wet performance. Noise and rolling resistance is less important. I would say 60% sport and 40% touring.
I have been looking at:
Falken ZE912
Bridgestone RE050
Pirelli (P7, Zero)
Dunlop SP01
Hankook (K105, V12)
Old 12-30-2010, 11:55 AM
Nevin's Avatar
Nevin Nevin is offline
Re: What size tire?
I've got 245/40zr17's on mine, with 8" wide rims.
HERE is a very handy tire size calculator that I often refer to. You'll find what sizes you can run that will measure the same diameter as stock, or find out how far off your speedo will be with another size tire.
Jesus is the remedy
2015 Expedition EL Ecoboost
