Old 04-12-2009, 12:39 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
will these struts work?
will struts from a 98 forester fit on the svx? i have a free set and i need new struts so i figured id find out just in case.
1992 silver/black LSL - 142,xxx miles
power mode switch, ecu crush, intake silencer removal, ecutune, B&M transmission cooler
1971 toyota landcruiser - project.... someday
Old 04-12-2009, 12:51 PM
Blacky Blacky is online now
Re: will these struts work?
No.
SVX struts are unique.
Old 04-12-2009, 01:14 PM
Green1995SVX's Avatar
This has been discussed so many times. You can only use SVX struts.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-12-2009, 01:33 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
I recall seeing someone redrilling their strut tower to fit the other Subaru bolt patterns. I don't know what that does as far as structural rigidity and overall integrity are involved, but I'm sure it opens the SVX up to a world of options.
Old 04-12-2009, 01:43 PM
This still won't solve the fact that our knuckles are significantly larger than other subarus. They won't fit on the bottom either.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 04-12-2009, 03:27 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
They'll fit just fine, provided you do the work needed to make 'em fit. If your asking if you can be a parts replacer then no, you need to do some work to make them fit.
Old 04-12-2009, 06:22 PM
ok, now that we have established the struts will not work, is there any parts that would be usuable on the svx? maybe rims/tires, cv shafts, sensors, etc?
Old 04-12-2009, 06:34 PM
legacyau legacyau is offline
from what i understand 05 onwards sti struts are similar but still have different sway bar mounts I am still to physically compare them, has anyone done this ?
Old 04-12-2009, 07:07 PM
Do you mean from a Forester? Not a whole lot will just drop in, most of the parts will require other things to be changed with them.
I've compared them. All other Subaru struts don't have swaybar endlink brackets on the struts like the SVX. The upper mount has different hole pattern and the raised section is larger on the Impreza struts. The knuckle for the Impreza is also thinner. It can be made to work, but is in no way a bolt-on swap.
Not the rims/tires, wrong bolt pattern and tire size. Not the rear CV shafts, not sure but unlikely for the front CV axles. Sensors, you'd have to check each individual part#.
Old 04-12-2009, 07:21 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Newer ('05 on ?) STi rims will fit, as they share our 5x114.3 bolt pattern.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-12-2009, 07:44 PM
Mensaf's Avatar
-Bill
I thought it was the older ones that fit. Don't the newer ones have the 5x100 bolt pattern?
Old 04-12-2009, 07:53 PM
Manarius's Avatar
Manarius Manarius is offline
No. The 04-05 STI has the 5x100 bolt pattern (well, guaranteed 04's, some 05's). Every STI after that has the SVX bolt pattern.
-Jason
-Obi Wan Kenobi
Old 04-12-2009, 10:06 PM
He's talking about a '98 Forester where the f%&# did STi come from.
Old 04-13-2009, 01:20 PM
SVXRide's Avatar
just checking to see if people were paying attention
-Bill
