Old 02-01-2009, 03:20 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Question Oil dipstick mystery
After any amount of driving, my oil dipstick has popped up from the check tube and is hanging sometimes an inch or two above the seated position. The last time it was out so far I could see the metal strip inside the tube. What gives? Does anyone elses do this?? Is my dipstick a jack-in-the-box? Im hoping this isnt from blow-by gasses from the cylinders Its only got 139K.
Old 02-01-2009, 03:37 PM
ARED 97's Avatar
ARED 97 ARED 97 is offline
Wink Re: Oil dipstick mystery
Just one of those things with an SVX, try replacing the o ring.
1997 Polo Green SVX LSI #316 49,000, garage queen, aka "The Green Queen" 1997 Brilliant Red SVX LSI #200, 167,000, daily driver, aka"Rosie's Rocket I" 1997 Brilliant Red SVX LSI#234, 106,000, summer driver, aka"Rosie's Rocket II"
1988 Red & White Silverado, aka "The Hauler"
2000 GRAND MARQUIS LS w/ handling package, aka "BIG BLUE"
1988 Mazda RX7 Convertible, aka " Lil Blue "
Old 02-01-2009, 03:47 PM
Mine does it too. I wrapped some teflon plumbing tape around the o-ring and it worked for a while but did it again after a couple of weeks. A new o-ring sounds like a good cure and cheap too. I got my power steering reservoir o-ring for 10˘.
Old 02-01-2009, 03:51 PM
It certainly is. The PCV needs replacing, to allow the case pressure to pass to the inlet.
Old 02-01-2009, 03:56 PM
essveeexxee essveeexxee is offline
10 characters.
Old 02-01-2009, 03:58 PM
10 characters.
Old 02-01-2009, 04:02 PM
wannarace928's Avatar
wannarace928 wannarace928 is offline
Send a message via AIM to wannarace928 Send a message via Yahoo to wannarace928
Classic SVX
What about when you have replaced the O-Ring and replaced the PCV valve and it continues to do it?
1992 Subaru SVX 5spd
1998 Pontiac Firebird Formula
1999 Chevrolet Camaro SS
2009 Subaru Forester - Mileage Junky
2009 Pontiac G8 GT
2017 Ford Mustang GT 6spd
Old 02-01-2009, 05:46 PM
Originally Posted by essveeexxee View Post
Wouldn't that trip a code?
No the ECU can't tell.
Yes mate, It can still happen, if the passages in the air box in front of the throttle bodies, are blocked with goo. This is the passages that connect the two cam cover breathers to the Ventilation valve.
If you look at where the two breather pipes enter the box, it looks like they just go straight in, but they both go into a small passage that connects through a restriction to the PCV valve.
These are where the engine flows the crank case pressure, under full throttle as the PCV valve is closed then.
I would pull the air box off and clean out the breather passages.
Old 02-01-2009, 08:02 PM
Usually just replacing the O-ring does the trick. It may not be pressure build up, but just vibration that moves it up. After getting a new O-ring, it should stop doing that.
Old 02-01-2009, 08:49 PM
that happend to my car when i bought it replaced the o ring like 10 months ago and havent had a prob since
Old 02-01-2009, 08:58 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
I was just wondering about this today. This a regular Autozone part?
Old 02-01-2009, 09:04 PM
liamrh's Avatar
liamrh liamrh is offline
I would do the pcv anyhow. It can cause some weird ****.
Old 02-02-2009, 12:06 AM
stiguy's Avatar
stiguy stiguy is offline
the pvc or the o ring?
Old 02-02-2009, 12:51 AM
I would replace them both. You could start with the o-ring.
Old 02-04-2009, 05:07 AM
Even with a bad O ring the dipstick should not pop without internal pressure.
As per Harvey's #8 post. Treat the cause, not the symptom.
Do the PCV valve. Clean the gunked up passages. Replace the O ring.
No more problems.
