Re: Oil dipstick mystery
What about when you have replaced the O-Ring and replaced the PCV valve and it continues to do it?
1992 Subaru SVX 5spd 1998 Pontiac Firebird Formula 1999 Chevrolet Camaro SS 2009 Subaru Forester - Mileage Junky 2009 Pontiac G8 GT 2017 Ford Mustang GT 6spd |
No the ECU can't tell.
If you look at where the two breather pipes enter the box, it looks like they just go straight in, but they both go into a small passage that connects through a restriction to the PCV valve. These are where the engine flows the crank case pressure, under full throttle as the PCV valve is closed then. I would pull the air box off and clean out the breather passages. Harvey.
Usually just replacing the O-ring does the trick. It may not be pressure build up, but just vibration that moves it up. After getting a new O-ring, it should stop doing that.
that happend to my car when i bought it replaced the o ring like 10 months ago and havent had a prob since
I was just wondering about this today. This a regular Autozone part?
I would do the pcv anyhow. It can cause some weird ****.
the pvc or the o ring?
I would replace them both. You could start with the o-ring.
You should be able to get a PCV valve, and probably a suitable O-ring, at any auto parts store.
dcb |
