Old 11-30-2008, 01:13 PM
PhaseII 4eat Swap
Is it possible? Yes it is.
After working for the past two days Hocrest, Melis, and myself have completed the first documented Phase II 4eat swap. Now, I don't even want to get into the wiring involved right now as it is EXTREMELY extensive. BUT the hardware is a direct bolt up... Here is a list of hard parts you will need.
1. Transmission
2. Torque converter (they are different)
3. Oil pump drive (they are different too)
4. 3-4ft. of new transmission cooler soft line
5. Flex plate
6. TCU (for a 6cyl)
7. Starter
8. Matching rear diff (most likely a 4.44)
We have two issues right now that we need to iron out still.
1. The speed sensor #2 reads a MUCH higher reading than ours did, so we need to find a way to convert the signal to match our dash.
2. There are two torque control signals from the TCU, right now we only used one of them but we are looking into solutions for this to get rid of the code.(Yes, Subaru uses torque control in their new transmissions for the same reason they did in ours, safety of transmission internals)
Old 11-30-2008, 01:25 PM
Wikedjuggalo's Avatar
Rebuilding
Re: PhaseII 4eat Swap
Wow... Good job tom and associates .
Old 11-30-2008, 03:46 PM
Kind of Subaru does a Phase II 4eat come out of?
Old 11-30-2008, 04:08 PM
Rebuilding
98+ I believe
Old 11-30-2008, 04:26 PM
Hondasucks's Avatar
Subaru Technician
Phase II = external spin-on filter, among other things. I posted a PDF a while back about the 4EAT and their differences, here it is:
http://endwrench.com/images/pdfs/4EAT.pdf
1986 VW Jetta
Old 11-30-2008, 05:02 PM
WOOT! Now for a 5EAT!
Thats the Phase 1. The later have a clutch to replace the band, and another speed sensor on the input to the gear train to sense load.
A better box.
Old 11-30-2008, 05:26 PM
If only they didn't cost so damned much... This whole project has been an idea of mine for a long time. Dave and Melis put up the parts and a car and let me have at it. But honestly the time put into making jumper harnesses (so it could always be returned to stock) wouldn't make the swap worth it if I was charging them to do it. BUT a 5eat w/ paddle shifters.... Thats the ultimate goal and this was just my stepping stone to make sure I could do it Now to find a 5eat in Harry's for $45... that would be awful nice
Old 11-30-2008, 09:03 PM
I'll keep my eye's open...
Yeah, the wiring is huge. There should be some pics up tomorrow...
Old 11-30-2008, 09:27 PM
Wait maybe 15 years and that might come true! How many SVXii will be driving at the 30th anniversary meet I wonder? Earl will probably own most of them.
Old 11-30-2008, 09:30 PM
I just got a 2003 OB trans there. I figure I'll start to see 5 speeds in 2-3 years.
And I plan to be driving mine well past the 30th meet
Old 12-01-2008, 05:11 AM
Sweet!
Great Work guys, as that'll open up replacement trannys considerably
Old 12-01-2008, 08:01 AM
Ok, I found a speedometer correction circuit board in the magazine Trevor had suggested to me quite some time ago (Performance Electronics for Cars). So I will have Dave/Melis order one of those so we can build and install it. This will rectify the speedo issue. No it is just finding out how to get that torque control code to go away while retaining its function
Old 12-01-2008, 01:13 PM
This should do the trick
May take a while to get it here but it should be our speedometer solution
Old 03-07-2009, 03:28 PM
back it today w/ a new trans after the front diff took a crap on us last time. We have it driving again. Unfortunately we were not able to get the torque control working properly, so we still do not have a fix for that. We were able to get the speedo corrector to work properly and dial in the speedo using a GPS to fine tune it. Now it is buttoning up the interior and mounting the new trans computer and speedo corrector. I have advised Dave and Melis to take it easy off the line, considering the shifts are much smoother than the PhaseI transmissions, I think it will be OK during shifts w/o the torque control. I don't like it, but right now I do not have a solution to fix it so we are going to have to make due.
Yay
