Old 05-05-2008, 02:14 PM
nextse7en's Avatar
Graphic Artist
Quick and easy.
During a compression test, what is the acceptable range of values in PSI?
Thanks,
Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 05-05-2008, 04:51 PM
Thanks,
Patrick
With the throttle wide open:
171 to 206psi Standard.
142psi limit.
28psi difference between cyl.
Old 05-05-2008, 04:54 PM
142psi limit.
W.O.T. and all 6 plugs removed...
blk 92' LSL w/ average mods
Old 05-05-2008, 06:17 PM
Is this a wind-up?
How exactly could you turn over an engine to generate pressure in one cylinder with all 6 plugs removed?
I had always thought that each cylinder was measured independently, with ignition in the other 5 contributing the motive power.
If I am wrong in this, can somebody please explain what turns the cylinders to apply the pressure?
Old 05-05-2008, 06:20 PM
Is this a wind-up?
The starter motor?
Old 05-05-2008, 06:22 PM
Is this a wind-up?
No I would not do it that way Joe
We just use the starter.
Old 05-05-2008, 06:26 PM
Originally Posted by Crazy_pilot View Post
The starter motor?
Accepted, but that's a simplistic answer to the question. Assuming the starter motor could turn over the engine, why would you need all six plugs removed, unless you had six discrete pressure readers screwed into each cylinder?
I'm making the assumption that the test involves only one pressure reader. Why not "run" the engine on 5 cylinders?
Old 05-05-2008, 06:28 PM
OK.
Why?
Old 05-05-2008, 06:29 PM
Is this a wind-up?
are you serious?
Old 05-05-2008, 06:31 PM
I think (I've never done a pressure test, so this is only speculation on my part) that the goal is to get the piston to stop at top dead center to get an accurate reading. With no spark plugs and no compression on the other cylinders the starter has an easier time turning the motor to get where you want.
The readings that I posted are done at 200 to 300 rpm, starter speed, .If you do it by starting the engine you would be at 600, not to mention the inherent danger of a fire.
Old 05-05-2008, 06:32 PM
Yes.
I am presuming there is only one pressure reader. Is there a reason why the engine can not run on 5 while one cylinder is being read? If so, explain what problem may be caused?
Old 05-05-2008, 06:43 PM
Thanks Chris.
That makes sense. With zero pressure at all the other 5 cylinders, the measurement at the cylinder under test will be more accurate. I suspect though, that the pressure gauge will only register the maximum pressure produced, so the TDC business is taken for granted.
Understood,
Ta,
Old 05-05-2008, 06:47 PM
Precisely, that's why all 6 plugs get removed, to allow the motor to spin freely.
Old 05-05-2008, 07:00 PM
nextse7en's Avatar
Graphic Artist
This thread is taking a turn to the ridiculous.
142psi limit.
Thanks Harvey.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
