Old 01-08-2008, 09:16 AM
sicksubie's Avatar
6spd swap started
I started my six speed swap finally yesterday.. Got the rear end done and installed minus axle nuts. Here are some pics
Center concole removed
Empty rear end
R180 rear with driveshaft flange removed and R160 with Flange still on
Removing the R160 Flange to put on the R180 rear diff.
The mounting studs that go out the back of the rear diff were too short on the R180 so I swapped the studs with the ones from the stock R160. The R160 mounting bolts are on the left and the stock STi ones are on the right
The rear going up into the car
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 01-08-2008, 09:21 AM
porschekiller porschekiller is offline
Banned
looks good, i just hope the mounts don't bang like mine. i'm putting in the rallispec.com mounts.
Old 01-08-2008, 12:31 PM
svxpert svxpert is offline
nice
i still have to do the rear flange swap myself. as soon as i get some rear sti axles! anyone have a line on a set of 2004 STi rear axles?
thanks
Old 01-08-2008, 04:47 PM
sicksubie's Avatar
Dinner, then starting to clear out the stuff in the engine bay that is in the way......
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-08-2008, 05:10 PM
What's with the sensor in the R180?
Old 01-08-2008, 06:36 PM
sicksubie's Avatar
I believe it has to do with the DCCD?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-08-2008, 06:54 PM
<<What's with the sensor in the R180?>>
i think its a thermo sensor to make sure it doesnt overheat.
Old 01-08-2008, 06:56 PM
BTW, whats the size of the nut on the rear flange? 28MM? i need to get a socket to remove it.
Old 01-08-2008, 07:56 PM
sicksubie's Avatar
I used a 1 and 1/16 fitting on my air gun......
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-08-2008, 11:25 PM
sicksubie's Avatar
The notched rear diff mount
engine bay
Front STi axle
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-08-2008, 11:33 PM
sicksubie's Avatar
finished rear end
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-09-2008, 07:55 AM
yes thats just a temperature sensor... You can swap over the plain drain plug if you please. Bobby make sure you get those axles clipped into the rear diff as well as the front
Old 01-09-2008, 08:04 AM
sicksubie's Avatar
Simply push till they pop right?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 01-09-2008, 08:08 AM
might need to give em a whack... I use a dead blow but be careful you do not split the axles boot
Old 01-09-2008, 12:27 PM
Dessertrunner's Avatar
A question do the current lot of 6 speeds with the R180 diffs have a 1:1 or 1.1 : 1 transfer ratio. It seems I am being told that they all had 1.1 :1 which I don't beleive to be true? I need to know to check the read diff ratio.
Tony
