Vendors for transmission resistor
Hi all,
I'm looking to pick up a new spec transmission resistor. Any suggestions where I could pick one up or order one? Thanks! |
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Something roughly equivalent to the original stock resistor.
![]() http://www.subaru-svx.net/photos/files/How-To/31030.pdf
How do you know when your resistor needs to be replaced?
Paul ![]() 1969 Corvette ![]() 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! ![]() 1995 Corolla ![]() 2003 Highlander ![]() |
Your transmission will shift abruptly, you will lose engine braking (put the shifter in '3' going down a hill and take foot off the gas; your revs will plummet), and most noteably your Power light will flash 16 times upon startup. This notifies you that there is a transmission fault.
http://www.svx-iw.com/svxiw/article/?article=79 The link above will tell you how to pull codes. If your resistor is dead, you'll get a code 11. |
It is located between the battery and the inner fender under the hood.
If you remove the two 10mm head bolts that hold it in, you can check the resistance with an ohmmeter. Good stock resistors will test at, or very close to 12 ohms. Factory range is 9-15 ohms. If it reads as an open circuit then it is very bad.
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 10-29-2007 at 06:20 AM. |
Mine read open circuit when it was removed and tested too.
My 5 speed doesn't need her resistor
You can have my stock resistor if you want it. I have a 5-speed and the PO left it on the inner fender. Pay shipping and it's yours.
