Old 10-08-2007, 09:38 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Arrow Swaybar bushings
Are any of these the right size for the fronts. The front set I bought from Dayle at motorsport warehouse are to short, they wont fit. I need the fronts bad, as my red 96 is squeaking worse than a mouse. Car sounds like its falling apart.
http://www.autopartswarehouse.com/pr...nsion_bushings
1995 POLO LSI 76K MILES SOLD
Old 10-08-2007, 10:40 AM
Check out my locker.
http://http://www.subaru-svx.net/pho...svxfiles|24445
They will need to be noched, and ground/sanded out to 18mm.
Old 10-08-2007, 11:27 AM
Speedklix's Avatar
Locker Link Solution
bingo (fixed)....
http://www.subaru-svx.net/photos/use...svxfiles|24445
so which ones did you use Tom, the energy ones? or is that dayle's installed?
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 10-08-2007, 12:03 PM
I like the Energy 9.5105G for the front.
Old 10-08-2007, 01:18 PM
Speedklix's Avatar
thats what I was leaning toward... no one around here stocks them though
I'm gonna have to order them or get a hold of the guys at indyauto.
while on subject... I also need to read this later:
http://www.subaru-svx.net/forum/showthread.php?t=24206
-Mike
[SIGPIC][/SIGPIC]
Old 04-28-2008, 01:41 PM
Merz's Avatar
Merz Merz is offline
halfsharkalligatorhalfman
So, are the energy bushings the best/cheapest option for swaybar bushings? I found some online for 13.08. Anyone find them cheaper?
What is the easiest way to grind out the hole? Thanks!
I've developed a bad clunk on the drivers side, so i checked the swaybar bushing, and its completely missing
`92 pearlie 220k
Tranny Cooler, shift kit, stage 1v4, d/s rotors, axxis pads, Perrin Pulley
'00 GMC Sonoma ZR2.
Old 04-28-2008, 02:03 PM
Merz's Avatar
Ok, I just found Chikes install thread here:
Good instructions with pictures.
Most people seem to get them from summit for $24.74 shipped. I found them here for $21.07 shipped. I looked all over and this was the cheapest i could find.
http://www.sportcompactonly.com/Ener...HOPFR100&st=90
`92 pearlie 220k
'00 GMC Sonoma ZR2.
Old 04-29-2008, 05:30 AM
dcarrb dcarrb is offline
You can get fromt sway bar bushings from Subaru: Part #20401PA020, about $15 per pair.
dcb
