Old 08-15-2007, 02:35 PM
Transmission jumping gears on highway.
My transmission is acting annoying.
1. In fourth, at highway speed (45-60 mph) it will jump from 4 to 3 for a second, then back to 4, hold that for a while (seconds, minutes, it varies), and do it again.
2. It also seems slow to lock the torque converter in 4th; it's revving maybe 1-200 RPM high at 60. When it's at the normal revs at 60 it stays there solidly without shifting.
3. About half the time I get a hard 1-2 upshift.
I've searched around and found a bunch of possible causes and solutions. Bad TPS, bad tranny resistor, brake band needs adjustment, transmission not reaching normal operating temperature, torqu converter gone gimpy, general tranny apocalypse...
I'm leaning toward bad TPS, because I also have an annoying hesitation from 1200-1600RPM, very much like there's a dead zone in the throttle. I'd like to know peoples thoughts on what else it could be though.
Old 08-15-2007, 04:46 PM
jeffast jeffast is offline
I kill more trannies then god
thats basicially what mine did when the tps was bad, changing it fixed the fast shifting around, and the slow lockup
1991 xt6 eg33?
1993 gc track car
Old 08-15-2007, 06:05 PM
processengr's Avatar
Both 92s we have had those symptoms, plus another when the TPS was worn, both were fixed when TPS was replaced($197 each, 1st Subaru)..The third symptom was the idle speed. It would start off ~600-700rpm then increase to about 900-950rpm 15 to 20 minutes later...
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 08-15-2007, 06:34 PM
Alright thanks guys, sounds like the TPS is the culprit. The major one at least.
I don't have the third symptom you described, processengr. My idle remains constant, according to the emmisions test I had done today, at 654 RPM, after about 30 minutes of driving.
Passed the emmisions test with flying colours too.
If anyone else has an opinion or thoughts on the matter, feel free to chime in.
Old 08-15-2007, 08:04 PM
kis86's Avatar
kis86 kis86 is offline
replacing something or another
Send a message via MSN to kis86
Tps
I cleaned my throttle body out a few months ago, and had the same problem! Turned out I hadn't plugged the TPS in completely
