Old 03-18-2007, 06:45 PM
richardstanley's Avatar
richardstanley richardstanley is offline
Lover of Alcyones
D or 3 ?
Just wondering, do you guys drive around town in 3 or Drive?
Old 03-18-2007, 07:16 PM
Manarius's Avatar
Manarius Manarius is offline
Drive. If you put it in 3, it binds up the tranny when slowing down.
-Jason
-Obi Wan Kenobi
Old 03-18-2007, 07:25 PM
-JJ-'s Avatar
-JJ- -JJ- is offline
Endangered Species
Send a message via MSN to -JJ-
??? realy??
I was told that suby recomended driving in 3 in traffic, to stop the trans constantly changing gears and thus heating up Not to metion extra wear!
Would be interested if someone could clarify!
I drive in traffic in 3 normally, but i change gear "manually" quite a lot
Cheers,
Jake
1992 Pearl / Black SVX
removed intake silencer, k&N pannel filter, trans cooler, 94 JDM 4eat, Noltec front swaybar mounts, Motorsport D&S disks with EBC Greenstuff pads
Old 03-18-2007, 07:38 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Please elaborate what you mean by "binds up the tranny when slowing down." I was thought that selecting "3" kept the transmission from going into overdrive. What effect does slowing down have on the transmission in 3?
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 03-18-2007, 08:13 PM
Manarius's Avatar
Today when I was driving up and down hills, putting the tranny in 3 made it act like a manual tranny (not free deceleration like in neutral). I thought 3 was good to stop tranny hunting when going up hills - not driving in traffic.
I was also told that shifting a automatic isn't worth it and could be potentially harmful to the tranny.
-Jason
-Obi Wan Kenobi
Old 03-18-2007, 08:40 PM
Lover of Alcyones
Aha, another question this made me think of. What advantage does the "manual" button give?
Old 03-18-2007, 08:43 PM
I have always driven in direct drive 3 around town and on winding roads, for obvious reasons. It is my opinion that if the selector had been labeled, 1, 2, 3 and O/D, Subaru would have saved a lot of the transmission problems.
Old 03-18-2007, 10:23 PM
Nomake Wan's Avatar
Retired
Since the 4EAT in the SVX is similar to the '90 Legacy's... I would assume that the manual button prevents the transmission from shifting down in whatever gear you have selected. In 'D' it does nothing, but in 2 and 3 it prevents the transmission from downshifting if you hit the throttle and are in low revs.
Old 03-18-2007, 10:36 PM
nextse7en's Avatar
Graphic Artist
Menarius,
It sounds like your resistor is failed or unplugged, that will cause that "downshifting" sensation in 3.
check to make sure its pluged in, located on the fender wall behind the battery.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 03-19-2007, 03:19 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Don't confuse low gear deceleration with the transmission "binding up".
On motorways at a sustained 70mph+ I drive in D with the "power" button off.
Otherwise, I always drive in "3" with "power" button on.
The manual button prevents the gearbox from using 1st gear when the stick is in position "2" or "3".
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 03-19-2007, 06:44 AM
3 for me
Old 03-19-2007, 07:08 AM
Originally Posted by TomsSVX
3 for me
In your 6 speed?
I know you have the power, but isn't that hard on the clutch?
Old 03-19-2007, 07:41 AM
Lover of Alcyones
Is there a "power" button and i'm just missing it? In my 91 4eat xt, the "power" light would come on when the pedal was basically on the floor. Noticed it coming on in the svx ( i like to pronounce it out haha Ssvks) the other day... there's a button?
Old 03-19-2007, 07:43 AM
RSVX RSVX is offline
Network Design Administrator
No, the power mode is engaged based on the 'urgency' in which you push the gas pedal...
meaning, if you floor it slow and steady, you will not get power mode... but if you slam it to the floor, or even have way as fast as you can power mose will engage.
Life is a game. Play to win.
Old 03-19-2007, 08:20 AM
Manarius's Avatar
Originally Posted by nextse7en
Menarius,
I'll have to take a look at that today - but I'm pretty sure that's standard activity when the 4EAT is put in 3. As soon as I put it in drive, that sensation went away because the clutch kicked in.
-Jason
-Obi Wan Kenobi
