Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 09-21-2006, 03:41 PM
Motorsport-SVX's Avatar
Motorsport-SVX Motorsport-SVX is offline
check out www.planetsvx.com
New Brake Rotor Option (very nice)
Just picked up finally a new rotor line
We are still going to be keeping our other
line of rotors (they have been great so far
with prices and quaility)
but for those maybe wanting to go a step
Up there will be about a 6 choice option
from these guys:
http://www.dba.com.au/default.asp
and Ill be stocking some of the midrange priced units, while being able to get all of them.
I know their prices are more, but think the Svx
owners would like more options for the hardcore
guys..
Ill have more info soon
My mom will forever live in me and
never be forgotten, one day Ill see her again
CLICK the LINK below to Visit the SVX Store:
http://www.planetsvx.com
http://www.motorsportwarehouse.com/svx/sig2.jpg
Cars in the garage:
92 Toyota Soarer Single Turbo JDM RHD
70 Boss 302 Mustang 39k original miles
97 SVX Lsi
92 Liquid Silver Murano-ized (1st of its kind)
71 Cougar Xr7 Conv 351c 4v 4spd
69 SS Camaro 350
71 Nissan RHD Fairlady Z
70 Stang Fastback
70 Amc AMX 390
71 240z
89 Conquest TSi w/ 5.0 v8 swap
84 Mustang GT Turbo conv
"good, if it bleeds, we can kill it ....."
Old 09-21-2006, 07:03 PM
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
I really like these...
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 09-21-2006, 10:00 PM
BordeauxComet's Avatar
BordeauxComet BordeauxComet is offline
no more SVX...
Send a message via AIM to BordeauxComet Send a message via Yahoo to BordeauxComet
Very nice!
Back when I was looking for rotors, I wanted to get some from dba, but I couldn't find a good place to order them through. Glad to see you'll be carrying them.
-Nathan
'03 VW GTI 1.8T
'94 SVX LS Bordeaux Pearl (wrecked, sold..)
Old 09-21-2006, 11:12 PM
Speedklix's Avatar
Locker Link Solution
drool.... two piece rotors that I shouldn't buy...
-Mike
[SIGPIC][/SIGPIC]
Catch you next at: ? Auto-X ?
Old 09-22-2006, 05:08 AM
gsodonis's Avatar
gsodonis gsodonis is offline
Better venting
I love their venting design!
They call their internal venting Kangaroo Paw. From their website: The Kangaroo Paw features 144 precisely positioned diamond and tear-drop pillars. More than just making the disc stronger, the pillars provide a greater surface area than traditional straight vane designs. Greater surface area means more effective heat dissipation and cooler running disc rotors. The Kangaroo Paw disc rotors will quickly remove the heat, cool the discs, and return to optimal operating temperatures ready for the next braking application.
Cool air flows in from the centre of the disc, while hot air is forced to the outside of the disc - regardless of rotational direction. The pillars provide greater strength across the disc rotor and reduce the tendency for disc distortion.
More efficient cooling improves brake pad and disc rotor life, and helps reduce brake fade.
Old 09-22-2006, 05:15 AM
RSVX RSVX is offline
Network Design Administrator
Im a nub in this field... so whats makes a rotor 2 pieces, and what are the benefits?
Life is a game. Play to win.
Old 09-22-2006, 07:17 AM
mikecg's Avatar
mikecg mikecg is offline
If you look at your breaks, you have 2 pads that press onto the rotor (1 on the front 1 on the back). The metal of the rotor inbetween the pads is solid. In a 2 piece rotor, there are 2 separte peices of metal (1 front and 1 back with air channels inbetween them. The advantage is in the air channels. The air passing through them cool the rotors better. By reduceing the temparature of the rotors, you reduce brake fade and also prevent warping.
Old 09-22-2006, 07:26 AM
gsodonis's Avatar
1 piece vs. 2 piece
A single piece rotor is machined from a single piece of metal.
Pros - least expensive method of manufacturing
Cons - If the machining isn't accurate, you can have disk surface run-out relative to the brake hat or the hub mounting surface
Cons - heavier than a two piece
A two piece rotor has a brake hat that is machined from a seperate piece of material from the rotor. The rotor remains cast, but the hat is usually machined from billet aluminum. The hat is then mounted to the rotor one of two ways, either solid or 'floating'. When solid mounted, the hat is bolted firmly to the rotor at multiple tabs machined in the rotor. When 'floating', rather than bolting the hat firmnly to the rotor, there are pins than locate the rotor radially, but allow for some misalignment axially. Under severe braking, the rotor can distort. By allowing the rotor to float, pad to rotor contact is optimized.
Pros - improved braking under severe conditions
Pros - the pins act as insulators - heat remains in the rotors and does not transfer to the hat
Cons - more expensive to produce
Two piece rotors are overkill for the street, but common in racing. They do look awesome however.
One piece - both rotors on the left:
Two Piece - rotor on the far right: Notice that the hat is gold and the many small silver mounting bolts that hold the hat to the cast rotor.
Old 09-22-2006, 07:39 AM
What He (gsodonis) said.
In this link there is more information, and picture 5 is worth a thousand words.
http://www.stoptech.com/tech_info/fa...parison.shtml#
Old 09-22-2006, 09:54 AM
thanks for the info!
Old 09-22-2006, 10:36 AM
Ill be finding out today I hope which all rotors they
make for our SVXs
We just got a set of their 4000s I think it was for a
local 95 Skyline GTR...those are pretty sweet.
Hopefully they have the full line for the SVX too
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-22-2006, 11:03 AM
nordique14's Avatar
Who watches the watchmen?
D'oh! This may mean I have no more excuses for not changing my warped rotors.
-Matt
Old 09-22-2006, 11:13 AM
If I were to choose I would fo with the 4000 6x6 wiper.
Old 09-22-2006, 11:41 AM
thats not a bad idea, maybe everyone post which model and or style you would most be interested in and Ill see what sort of pkg they can put together for us It doesnt have to be immediate, but down the road.
This way If I decide to pre order some stuff, Ill have an idea of what
some of you may want so its on the shelf down the road.
Cars in the garage:
97 SVX Lsi
69 SS Camaro 350
70 Stang Fastback
70 Amc AMX 390
71 240z
Old 09-22-2006, 12:35 PM
nordique14's Avatar
I would be in for the DBA Slotted or the 4000 6x6 Wiper depending on the price.
Time to get the car to stop shuttering when I brake.
