Is my offset too low to drop the car??
I am trying to figure out if my wheels will allow me to use dayles drop kit to lower the car, or whether the low offset of the wheels will cause rubbing when lowered.
The Scenario: 18" x 8" Enkei CP01's 38mm Offset 225/40/R18 Pirelli Pzero Nero Tires The springs: Motorsport SVX's 1.25" Front / .75" Back Drop Springs http://svx-motorsport-accessories.st...opsprings.html Does anyone have comment on whether these will fit together or not? Also, does anyone have pictures or info on the K&B drop springs?
1992 Subaru SVX LS-L Ebony Mica: Custom Cold Air Intake, Smallcar Shift Kit, ECUtune Stage 1v4, Flowmaster Exhaust, UR underdrive pulley, 4.11 gears, iRotors Drilled and Slotted rotors, Axxis Brake Pads, 18" Enkei Wheels w/Pirelli Pzero Nero M+S, 20% Window Tinting, K&N Panel Filter, Rockford Fosgate Sound System w/XM Radio, Removed Intake Resonator *SOLD* 2003 Subaru WRX: 2003 Impreza WRX (Aspen White); Vishnu Stage II; IHI VF-34 Turbo; Walbro fuel pump, STi Injectors, Vishnu Up-pipe, Down-pipe and Signature 3" Cat-back; Samco Intercooler hoses; JIC Coilovers; STi A-arms; Whiteline swarbar bushings; Stoptech 13" rotors w/4-piston calipers; Braided Steel brake lines; 17" Rota Wheels with 225/45/17 Falken Azenis (R-Comp). Charlottesville, VA Represent! (voted #1 place in America to live!) http://www.subaru-svx.net/photos/user.php?Amazonparrot |
if it doent rub now then it shouldnt rub after the install talk to dayle directly he would know best
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
It will probably rub in the back. If not during normal driving, everytime you hit a bump.
I'd guess those wheels would rub. I've got 42mm offset 8" wide wheels, and I certainly don't have more than 1-2mm of clearance. The 38mm offset would be really pushing it as it would make that gap even smaller. You can always get new wheels
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
"Its the car. Chicks dig the car!'
Tom DOES have a point...the chicks do dig the car:P Is there any definitive way of finding out whether they will rub...i really want that front gap gone....and what about rolling the fender lining in...not that I really know what that entails
You'll probably have to add camber bolts to the rear and then run at least a degree of negative camber front and back to keep the tires from rubbing -- educated guess.
-Bill
You could always try adding 300lbs in your trunk (or 2 large passengers in the back) to see if you can get the tires to rub while driving.
Bring them up to me. I got the springs on my car. I can also test the traction of your tires.
If you don't have time to do the other stuff, I'll measure my current clearance and give you some calculations that should give a good indication as to rubbing with drop springs.
If you're worried about gettin the ladies, you could buy my old Konig Flights. Check May on the SVX calendar for undeniable visual proof of sexyness Juuust kidding...one is cracked. You can still buy them though...smokin' deal if you know where u can get them fixed!!
there are a bunch of places that do rim repair around here (thank you MN winters) how much? balencing them once they're repaired is a b1tch though
they will probably rub on the rear if you have more then
one passenger. My Murano wheels are 7" wide with a +38mm offset and that car has my springs in it, on hard bumps on the freeway it will slightly rub, you can hear it, although theres no damage. With 8" wide wheels like you are asking, it will be a little closer. Mine doesnt bother me near enough to worry about it but I rarely ever have more then one passenger in my car, even with a 2.5 yr old in the baby seat in the back its not a problem. The rear lip is pretty wide, you can carefully fold it upwards to add about 1/4" of clearance, which helps alot.
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
