Old 01-14-2006, 10:06 AM
rbalach rbalach is offline
ECU error code checking pictures
Took some pictures the last time i was checking error codes, thought i'd post them. Hopefully it will help somebody.
For detailed info on how to check codes, go to
http://www.svx-iw.com
click on: SVXIpedia
click on: Checking Error Codes (Category)
click on: How to Check Engine (ECU) Trouble Codes
There are also instructions in the "How To" section.
Old 01-14-2006, 10:38 AM
Nice pictures!
If you don't mind I'd like to add them to the SVXipedia instructions.
Old 01-14-2006, 10:47 AM
Originally Posted by Earthworm
Nice pictures!
Thanks. I don't mind at all, feel free to use them.
Old 01-14-2006, 11:24 AM
I will write up a How-To on it and post it there. Thanks You know what they always say - a picture is worth .......
Old 01-14-2006, 12:18 PM
By the way, i was unable to clear the codes by using both wires in pin1 and pin2 of the black connector. For some reason it just wouldn't clear. I had to disconnect the battery for about 1hr for the codes to clear. Might want to add this to the How-To write ups.
Old 01-14-2006, 12:23 PM
I've successfully done it. You have to turn the key on/off for it to work I believe.
Old 01-14-2006, 01:00 PM
Thats what i did, but it wouldn't clear for some reason. I followed the instructions in the svx-iw webpage.
Old 01-14-2006, 02:13 PM
Did you start the car and then stop it with both wires in the connector? You need to do that, not just turn the key on and then off.
Check Here to see the How-To on reading the codes. I wrote up the instructions and added your pictures.
Old 01-14-2006, 05:15 PM
Yep, now that you mention it, i think i did start the car up, let it run for some time and then turned it off.
Anyways, the document looks good, and my pictures look good too How about adding the table that shows the explanation for each code into the doc ? People using the doc will not have to go hunting for that info in a separate file.
In case you are wondering, yes i'm an engineer, so i like my documentation to contain all relevant info
Old 01-17-2006, 10:48 AM
Oops...I admit sometimes I don't read my own notes
