Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 11-18-2004, 06:52 PM
nextse7en's Avatar
Graphic Artist
Thumbs up Your opinion please
EDIT, bringing this back from the dead because of a post a few threads down.
I've cleared out my taillights, and I just wanted your opinion... keep the diffusers out? Or put em back in?
Heres before... just ignore the condensation.
And after...
edit - see 4th page for pics
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 11-18-2004, 07:04 PM
AFBeefcake's Avatar
Subaru Swapper
Got any pics of the whole back of the car. I would like to see how it looks.
2005 Legacy GT
My WRX's Cardomain Page
Old 11-18-2004, 07:07 PM
nextse7en's Avatar
Graphic Artist
AFB - within a week or so... my passenger side lens is cracked all to hell - parts are on thier way.
Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 11-18-2004, 07:15 PM
SVXer95 SVXer95 is offline
Word to Yo Motha
Nice Color
Collin
1995 L AWD
Locker
1987 Porsche 944 turbo
Old 11-18-2004, 08:05 PM
SVX-FF's Avatar
SVX-FF SVX-FF is offline
Live it, Love it, Breathe it
Keep them out!!!!
They look way cool.
I have already taken my center ones out. After seeing your corners they are next on my list.
Steve
03 Ford Expedition(hers)
Are you in?
My Old Locker
A 4.11 Founding Father
Reading IX
[SIGPIC][/SIGPIC]
Ya I was there
Old 11-18-2004, 08:13 PM
rob_4187's Avatar
rob_4187 rob_4187 is offline
You're mine!!
Send a message via AIM to rob_4187
Yeah that does look pretty sweet. I think im gonna take mine out now!
Teal 92 SVX LS L with 103k
Engine: Stage 1, 3 in filter with heat sheild, underdrive pulley, NOS fogger system (75 shot)to be installed soon Sound:1 10" infinity with 230 continuous watt Dual amp (we have small trunks)
Old 11-18-2004, 08:14 PM
n00b on demand's Avatar
keep it like that...looks awesome
Old 11-18-2004, 08:21 PM
It looks very clean, how much trouble was it?
When I did my center light, on an 80f day, it was not too bad. When I tried Nicks on a cooler day, (65f?) I cracked it.
Old 11-18-2004, 08:35 PM
THAWA
If this diffuser is what I think it is you need that to have the correct beam pattern for your lights. Course I could be wrong but can you post a pic of what you took out?
Old 11-18-2004, 08:42 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Agreed. Looks Terrific!
-Chike
2006 Steel Gray WRX TR (sold)
Old 11-18-2004, 08:46 PM
How would i go about doin somethin like that?
Old 11-18-2004, 09:48 PM
i usually disagree with most non-performance-related mods, but i have to say it looks great. someone please find a reason we shouldn't do this before i talk myself into it.
Old 11-18-2004, 10:38 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
referring to the "after" picture, it does look great, more sexy, like a newer design in the close distance.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 11-18-2004, 10:47 PM
nextse7en's Avatar
Graphic Artist
Glad you like it...
Wow, I didn't think so many people would like it.
The following is a how to of sorts...
In your trunk remove the false floor over the spare tire, roll up the carpet and gently peel back the trim (carefull not to break the little plastic retainers...
Using a deep 10mm socket - remove the 6 nuts holding in the taillamp assembly to the car- disconnect the wire plug and take the assembly inside.
Preheat your oven to 225 degrees.
Remove the light bulbs.
Using a flat head screwdriver - pry the housing away from the tabs on the lens gently - and insert somthing (I used paperclips) to keep the housing pulled away from the tabs.
Once that is done, your ready to bake!!!
***WARNING & DISCLAIMER***
Oven temps vary - use a thermomiter to ensure your oven doesn't exceed 225 degress - anything hotter than this will PERMANANTLY WARP AND DESTROY YOUR LENSES, it's not my fault if your significant other come in the kitchen and decides to cook dinner and turns the oven up. (This happened to me on my sidemarkers)
Put the lens (one at a time, to give you time to work) in the oven for about 7 minutes - watch them carefully to insure that nothing odd is happening to them.
When they come out - they should be nearly to hot to touch - using a flathead screwdriver - carefully pry the lens away from the housing enough to allow you to grab the edge of the lens with one hand and the housing with the other. Pull slowly - the parts should separate fairly easily - if you have condensation in your lenses - wear gloves - the steam that comes out my be hot enough to burn you.
If its hard to pull apart STOP!!! One of your tabs is still holding onto the housing - OR- you havn't gotten the unit hot enough... Failure to heed this advice will result in this...
Assuming you had no trouble - pull out the diffuser and that flexy plastic thingus and discard it - thats the little bugger responsible for all of your condensation problems....
For those of you who asked... the diffuser looks like this.
Wax and buff both sides of your lens thougroghly. (I used turtlewax)
Put the housing and the lens back in the oven - same temp same time, this is to make it easier to press the lens back into the housing...
Press the lens back into the housing - taking care to press it ALL the way back in - if you don't, the lens will stick out from the body of your car in an unattractive way.
Installation is the reverse of removal.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 11-19-2004, 12:11 AM
THAWA
yeah you need that diffuser to create the correct beam pattern for your lights. I'd strongly recommend not removing it. Yes it looks super hot, but a lot of things look super hot. There's your reason kenneth
