Old 05-03-2011, 05:04 PM
The Molinator
Hydraulic Lifts.. ???
Is there a "cheap" source for hydraulic hood and trunk lift supports? They're about $60-70 from online OEM part houses.. . Yikes!
Hoping So.. . Tired of getting partially decapitated, when I forget the wood support stick! .. or getting scared from the severe trunk SLAM!
Thanks, Jim
Jim
Old 05-03-2011, 06:05 PM
kinz kinz is offline
Re: Hydraulic Lifts.. ???
I know there is a write up on the hood I got a link to the trunk in my signature. Very similar process for the trunk I did will work for hood
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
Old 05-03-2011, 08:11 PM
The Molinator
is there a trunk strut redo with info? ... or did it never work out?
Thanks, Jim
Jim
Old 05-03-2011, 09:38 PM
kwren's Avatar
kwren kwren is offline
Hood, yes! Attached is a graphic for the bracket for the strut... the way to get a professional job. The nuts are self locking good quality and keep the other component centered like it should be.
Trunk, no...
Mickey Mouse or Dealer only.
Keith
Old 05-03-2011, 10:17 PM
There finally is an aftermarket option which allows the trunk to open the full 90 degrees that the OEM struts did.
Parts list, installation writeup and photos.
http://www.subaru-svx.net/forum/show...uts#post668295
Old 05-04-2011, 06:15 PM
The Molinator
SO... I just order kits from Lift Support Depot for the trunk job (eBay link is closed), but order the parts for the Hood job (other thread) separately.. or do they make "kits" also.. ??
Thanks, Jim
Jim
Old 05-04-2011, 07:02 PM
The Molinator
I mean.. . from SPD.. . ??
.. . I wanna do the best.. most recent mods.. for both hood and trunk gas charged struts. These How-To's tend to flow.. as someone perfects a good mod.. into a better one! So for the hood, I should order SPD struts (SPD GSNI- 2449-89) and ballstuds directly.. then purchase bolts + washers myself. AND, for the trunk, I order "kits" from Lift Support Depot (#49136) for $33.30 each? SOUND RIGHT?
Thanks, Jim
Jim
Old 05-04-2011, 07:14 PM
Jim,
Click HERE for the easiest way to do the hood strut replacement.
Old 05-04-2011, 07:32 PM
The Molinator
Should I try to get parts for both at ONE supplier.. or is the best now.. to get the hood struts at SPD.. and the trunk struts at Lift Supports Depot.. ??
Thanks, Jim
Jim
Old 05-04-2011, 09:51 PM
Thanks, Jim
Use SPD for the hood struts and Lift Supports depot for the trunk struts. Members have tried to use SPD struts for the rear without too much success. The specs were just not close enough...
Old 05-04-2011, 10:12 PM
The SPD trunk struts worked great for me. It was the ball studs that created the work. The SPD ones however don't hold the trunk open at all angles. It does quite simply just hold it up with no issues for me.
Old 05-05-2011, 01:18 PM
The Molinator
OK!.. Do the nylon washers come with the SPD struts for the hood? or do I need to find them somewhere?? .. . Are they part of the stock system.. and retained for this use??? Does the hood ball stud just go in an existing threaded mount on the hood???? [I see list has (4) ball studs to order].. . I'm starting to hallucinate now.. .
Thanks for all your help! The Depot kits are ordered.. and SPD's will be today!
Thanks, Jim
Jim
Old 05-05-2011, 01:37 PM
The Molinator
Are you using the nylon bushing only to center the ball stud shaft in its hole? or are you also using the outer flange of the nylon washer to gain a lock washer effect when tightening the (regular) nut?
It seems a metal bushing might be more solid and stable.. along with a lock washer.. or better yet.. a lock nut.. ?? Just wondering.. .
Thanks, Jim
Jim
Old 05-05-2011, 01:40 PM
Thanks, Jim
The nylon washers are retained from the stock system, but you don't actually have to use them.
You need 2 ball studs for each hood strut, one that threads into a captive nut inside hood, one that you bolt to the modified stock mounting bracket on the car.
I'm actually going to order a couple sets of trunk struts now myself, I haven't done those as yet.
Old 05-05-2011, 01:41 PM
Thanks, Jim
A lock nut/washer or just a small washer would not be a bad idea. I think the nylon washer is just to center the ball stud in the hole.
