Old 03-26-2011, 07:27 PM
Gamesy's Avatar
Gamesy Gamesy is offline
cfm to hp conversion
i was wondering if anyone knows what the the ratio was for CFM to horsepower conversion was for the eg33
Old 03-26-2011, 08:07 PM
Re: cfm to hp conversion
Not really sure what you are looking for, but;
If we have a 202.5 CID FOUR STROKE engine,
turning at 5400 RPM,
assuming 100% volumetric efficiency,
the engine pumps 546,750 CID/M.
Or 316.40625 CFM.
Sooo our 230 HP takes 316.4CFM,
or .7269135 HP per CFM.
Or 1 HP per 1.3756793 CFM.
Why do you ask?
Old 03-26-2011, 08:20 PM
Gamesy's Avatar
gauging turbos which are too big or too small
Old 03-26-2011, 08:25 PM
I am not the guy to ask.
I have a 1750 CFM belt driver supercharger on my Claret.
But with the right pulley combination I can make the SC smaller.
Old 03-26-2011, 09:29 PM
Gamesy's Avatar
i tried PMing Tom but his box is full
Old 03-26-2011, 09:41 PM
YT has not done a turbo 3.3...
yet
Old 03-26-2011, 09:59 PM
yet
Gamesy, check out Garrett's site (Link), they have a lot of good info regarding turbo selections. Around here somewhere I have the calculations showing that for ~600 HP you'd need either a single GT3788 or 4088 pushing about 23-25 PSI, or a pair of GT2860RS in the 76 trim, 0.86 A/R running the same pressure. A TT setup for that sort of power would be difficult though, those turbos would be running right to their upper limits. For those power levels the engine would be consuming 44-63 lb/min of air. Not sure what that works to in CFM.
Old 03-27-2011, 10:44 AM
Gamesy's Avatar
thx crazy, but i dont plan on running that much power lol just to put the car a little over 300
Old 03-27-2011, 01:33 PM
radarwhiz's Avatar
Fairmont State University
Originally Posted by Crazy_pilot View Post
check out Garrett's site Link
Great info here. According to their formulas, assuming eg33 VE is ~92%, for a target HP of 300 we'd only need 2.75 lbs of boost. That sound right to anyone else? seems a bit low to me.
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 03-27-2011, 02:32 PM
If you did not alter the stock VE,
with the appropriate A/F ratio,
you would only need 7.5 PSI,
OF COLD AIR,
to make 345 crankshaft HP,
in theory, of course.
Old 03-27-2011, 03:40 PM
Gamesy's Avatar
OF COLD AIR,
not sure what VE is short for.
so the assumption is that stock 230 crank hp is roughly 180 whp
7.5psi would be roughly 270.
roughly what an sti puts to the wheels.
Old 03-27-2011, 03:43 PM
dragoontwo dragoontwo is offline
Volumetric Efficiency
'92 SVX LS Pearl White - 6mt
radarwhiz's Avatar
VE=Volumetric Efficiency
In theory.
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 03-27-2011, 04:12 PM
radarwhiz's Avatar
OF COLD AIR,
I'm doing a bunch of equations for different displacement, HP target, VE, RPM, and intercooled or not just to understand the theory.
With your example of 345 HP at 92% VE, ~12:1 A/F, 130 deg. manifold temp, at 6500 RPM it would need 7.9 lbs.
Does VE change with forced induction or is that changed with engine mods, ie: intake or exhaust mods, ported heads, ect?
Elazar
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 03-27-2011, 08:04 PM
~12:1 A/F,
Some musings;
Volumetric efficiency changes with engine design, and is different at almost all RPMs.
With our IRIS we can achieve over 100% VE!
12:1 A/F is a safeish, but not ideal ratio.
Our average intake manifold temperature is 200°f!
Sean, "musings", nice choise!
