Old 12-12-2010, 04:35 PM
Weatherstripping
Is it possible to remove the whether stripping from around the drivers door without damaging it and then reinstall it on another car? (The part that is attached to the door.) The stripping on my drivers door is split and I would like to replace it with some from a parts car if possible.
Old 12-12-2010, 04:46 PM
Re: Weatherstripping
Yep, none of it is glued on. Just a couple push pins at the front and various little clips.
Old 12-12-2010, 04:48 PM
Thanks, it has been torn for a few years and it would be nice to fix it. Glad to know it isn't major problem..
Old 12-12-2010, 04:55 PM
Most of the way around, it is just pressed in a track and pulls out easily. At certain areas, there are plastic trim plugs holding it in, use some needle nose pliers or a trim tool and you should be able to remove those.
So yes, take you time and it's possible. I'd remove the damaged one first so you know what to look for when removing the good one.
Old 12-12-2010, 05:07 PM
Anyone out there happen to have one??
Old 12-12-2010, 06:31 PM
I'll check out the one on my parts car tomorrow night. Just the driver's side?
Old 12-12-2010, 06:42 PM
Yeah the passengers side is ok. I appreciate it.
