Old 07-02-2010, 08:21 PM
picked up a set of STI BBS rims - problem
Ok, so I got lucky and nabbed a set of silver STI BBS rims in Orlando the other day. The rims are in great shape, except for one possible problem. On each of them, there's a sort of tapered and splined ring that sits where each of the lug nuts goes. One of them is missing. You can see them pretty easily in this picture (the gold gives better contrast than the silver):
Do I need that little spacer ring or no? Any idea how to get one? I looked on subaruparts.com, but it's not listed there. Anyone know what it's even called?
Old 07-03-2010, 02:45 PM
wdb wdb is offline
dances with roads
Re: picked up a set of STI BBS rims - problem
Not just yes, hell yes. BBS wheels have steel seats for the lugs, and you're missing one. I have an STi, and I didn't even know they were removeable.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 07-03-2010, 02:54 PM
They are splined and they don't look like they're supposed to be removed. So where do I get one?
Old 07-03-2010, 07:01 PM
Maybe talking to someone at a rim repair shop would help.
Old 07-03-2010, 07:05 PM
Yes, those are mandatory. Wheel repair shops are able to press in new sleeves (at least the one my shop deals with is). How is the alloy surrounding where the sleeve should be? It would have taken considerable force to remove it.
Old 07-03-2010, 07:28 PM
The alloy is fine around it. Looks like it could be popped out from behind relatively easily. I'll see about a wheel repair shop then. Thanks guys.
Old 07-31-2010, 08:49 AM
Got one from a subaru dealership.
Old 07-31-2010, 09:09 AM
NeedForSpeed NeedForSpeed is offline
Great!,
also, thanks for posting the solution
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 07-31-2010, 09:47 AM
Originally Posted by NeedForSpeed View Post
Great!,
Yea there are so many threads that end just one post early. And that last post is of course the most important.
Old 07-31-2010, 10:33 AM
agreed!
The reason I posted my appreciation
Old 07-31-2010, 11:33 AM
Cam Cam is offline
You could put one in with an air hammer (rivet gun). Use an aluminum or steel flat die, and make sure you lubricate the crap out of it. Make sure it is flat, and turn the psi on the compressor down.
This is of course assuming you have a rivet gun and compressor
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
