Old 10-06-2009, 03:06 PM
Kind of Bummed about talk with Body Shop Tech
Took my car for an opinion on the small patch of rust behind the rear wheel, and was basically told that they can't really fix it. He said it was rusting from the inside out, from between the seams where the 2 panels of metal join together. According to him they could sand it down and paint it but not guarantee that it won't come back in 6 months.
Anyone else ever looked into repairing this area? Right now it looks fine, but I wish I could do something to prevent the area from getting worse.
Old 10-06-2009, 03:47 PM
BoxerFanatic's Avatar
Re: Kind of Bummed about talk with Body Shop Tech
I dunno...
at that point, I might consider some rust inhibitor chemicals that convert rust to a non-actively oxidizing compound, and then cover the area with an undercoating or something...
Eastwood and other car restoration suppliers may have some products for stabilizing and preventing further rust on non-replaceable parts.
I know my dad uses POR-15, and some stuff that was developed for the navy to prevent rust on ships, when he restored is sports car, and now his 40's era fire engine.
I would think there would be solutions otherwise....
If all else fails... with various parts cars around, perhaps see if you can get that section of bodywork cut off of another car, flanged for an under-lap, and welded into your car's surgically de-rusted fender... but that will take some work, and some skilled work at that, to lay a patch in there without warping and such... As the tech said... there isn't a nearby seam above or aft of that area, to blend a patch panel into.
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 10-06-2009, 03:48 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Use some of that reversal primer. I forget the name, but it stops rust and turns existing rust to a hard finish. Iron men use it on I-beams when they are exposed to the environment.
Old 10-06-2009, 03:55 PM
Sean, bring it to The Pumpkin Carve so that Jerry or Ashley can take a look at it.
They both do GREAT work!
OT
Old 10-06-2009, 04:34 PM
Manarius's Avatar
Manarius Manarius is offline
OT
Heh, they'll really like mine then. Sean's is like baby rust compared to mine.
-Jason
-Obi Wan Kenobi
Old 10-06-2009, 04:49 PM
Green1995SVX's Avatar
My car had very similar rust before I had it repainted. The shop cut out that section entirely and welded in new metal.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-06-2009, 04:54 PM
OT
I would Tom, but my wife is working both days that weekend which means I've got the kids. I do want to come down pretty soon though, I'm tired of seeing that CEL for the EGR.
Old 10-06-2009, 07:48 PM
I guess that is the way to do it. Must have been pretty expensive.
Old 10-06-2009, 07:57 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Get that area sanblasted and remove the wheel well, spray some undercoating in the corner, install wheel well, etch prime over sandblasted area, prime,paint, clear and your done.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-06-2009, 08:10 PM
That will work? If I take these instructions to shop do you think they would be able to do this? By the way how far are you from Harrisburg?
Old 10-06-2009, 08:12 PM
That's what I would do. I'm probably about 2.5-3? hrs away I think.
Seth
Past subies:
Other toys:
Old 10-06-2009, 10:20 PM
+1
Just did this on the 5-Speed Ebony a few months ago.
Old 10-07-2009, 04:08 AM
+1
Are you welding in a new section from a rust free donor car, or some other way?
Old 10-07-2009, 04:37 AM
SomethingElse's Avatar
word words wording
From an exterior point of view you wont need to cut from a donar car. I dont know what goodness is brewing under that mess though...it does not look as bad as this..i had to cut a whole quarter from a donar.
Eric
Old 10-07-2009, 07:34 AM
At this point with my car the rust is so bad that my only route in complete replacement of the quarter panel with a new one. Fortunately they're only $300 or so each. I'm also going to have to rebuild the inner wheel wells a bit.
