Old 03-31-2011, 12:58 PM
Gamesy's Avatar
Gamesy Gamesy is offline
what oil do you use?
I was wondering what oil everyone uses for their cars.
Old 03-31-2011, 01:00 PM
Re: what oil do you use?
Are you wanting the weight or brand?
Old 03-31-2011, 01:14 PM
dcarrb dcarrb is offline
Havoline 10W-40. My brand of choice for 35+ years, thought I figure brand doesn't matter that much.
dcb
Old 03-31-2011, 01:16 PM
AMSOIL 10W30, but only after I did a full re-seal of the motor. I ran Royal Purple last year but wasn't impressed... All of a sudden my car was smoking on start-up and a bit at idle... Back to AMSOIL when she comes out of storage next week.
Old 03-31-2011, 01:24 PM
Mobil1 10w30
Old 03-31-2011, 01:27 PM
Old Fogey
+1 for M1 10w30 in both my Subies.
Glenn
Old 03-31-2011, 02:09 PM
Gamesy's Avatar
both weight and brand, mainly weight
Old 03-31-2011, 02:27 PM
I only ever used Mobil 1 10w30 in my white car. So far I've been using Castrol 10w40 in my blue car and I've not yet changed the oil in my black car. I will probably switch to M1 10w30 for both of them next time around.
Old 03-31-2011, 02:54 PM
LarryIII LarryIII is offline
Mobil 1 10W-30 in all SVXes and the Outback turbo wagon.
Larry III & The Beautiful Naviguesser
'19 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
'08 Harvest Gold Outback 3.0L. L. L. Bean...."AIJOU"
'07 Gray Diamond Pearl Outback XT Ltd..."AH SO"
'05 White Pearl & Silver BAJA Turbo..."AH HA"
'97 Bordeaux Pearl SVX LSi..."SUBYDOO"
'94 White Pearl SVX LSi..."PEARLY"
'92 White Pearl SVX LSL w/touring pkg..."SVXY"
'92 Teal SVX LSL w/touring pkg..."ALCYONE"
'96 Polo Green LSi ... "MIDORI"
'00 Black Dodge VIPER RT-10... "VINNIE"
Engineers do it with precision.
English teachers are novel lovers.
Home: larrysingeriii@comcast.net
SVX FEVER, CATCH IT AT A MEET NEAR YOU !!
Old 03-31-2011, 03:44 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
I only use 10-W40 cause of the age and likelihood of leaking. Should it be lighter or does it really matter?
Mods: ECU bead crush, 15 min mod, 20 min mod, drilled/slotted rotors & Axxis ceramic brakes, SS lines, 17" Evoke F1 wheels, XS-HF137 Sony Xplod speakers, 6000k HID's (lows & fogs), resistor mod, 1˝" Sleek Spoiler mod, custom exhaust by svxfiles, '02 WRX aluminum racing radiator by svxfiles, Summit Racing 400# x 300# springs w/ Koni's by svxfiles, ClassGlass fiberglass hood /w scoop, Nevin's rear sway bar, '97 grille, phenolic spacers, custom LED interior lighting, custom paint.
Old 03-31-2011, 04:07 PM
Cam Cam is offline
It is possible that a lighter weight is better for tighter oil passages, such as the ones that may have gotten through the assembly line at subaru. But with the age, the passages have most likely worn enough to not matter., and 10w30 is not THAT thick of an oil.
I run royal purple 5w30 with a Mobil1 filter, and have not noticed anything funny with smoking on startup or anything like that. Then again, my rings, bearings, seals, and everything else on my engine are BRAND NEW.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 03-31-2011, 04:54 PM
Bobb Bobb is offline
Hi everyone, Mobil says 10W30 unless the temp goes below zero.Then 5W30 is recommended. If you read the owners manual it lists oils like 10W40 and heavier single grade oils if you operate your SVX under severe conditions. In preparation for our west coast trip last summer I filled up with 10W40 because of the high temps in the desert out west. Normally I use 10W30. In any case all oils I use are Mobil 1. They even have a high mileage oil now. I don't drive the old girl in the winter. Take care, BOBB
Old 03-31-2011, 05:57 PM
I'm partial to Pennzoil, 5W30 in our climate.
Old 03-31-2011, 06:23 PM
On west coast, 10-w30.
Old 03-31-2011, 06:30 PM
Huskymaniac's Avatar
Uses the ignore feature
In winter I use 5W-30 of Quaker State High Mileage or Pennzoil High Mileage. In summer I am going to use 10W-40 of Quaker State High Mileage.
Quaker State HM has a surprisingly good viscosity index. The 10W-40 will not get excessively thick at ambient temperatures and will remain thicker at summer operating temperatures to help reduce leaks. HM oils also have greater cleaning ability and seal conditioners.
Tony
