Old 11-04-2011, 09:20 AM
Crankshaft socket
The Subaru Part is about $75...yikes! I need the socket to position the pistons correctly.
I've looked online and came across a number of aftermarket sockets for about $15, but they need the inner diameter size of the crankshaft snout to ensure proper fitment (checked the svx manual without much luck ).
Old 11-04-2011, 09:55 PM
kwren's Avatar
kwren kwren is offline
Re: Crankshaft socket
What is a crankshaft socket?
Thanks,
Keith
Old 11-04-2011, 10:02 PM
It's a Subaru specific tool that locks into the woodruff key on the crank to allow it to be turned to locate the wrist pins, which in turn lets you remove them and then the pistons. Looks like this:
What I've always done to rotate the crank is just install the crank pulley bolt finger tight and use it to turn the whole assembly. Just keep turning to the right, unless there's something very wrong with your rotating assembly it won't tighten up much turning and can easily be snapped loose after.
Old 11-04-2011, 10:47 PM
^That's what I did when I did the timing belt last time.
Old 11-04-2011, 10:49 PM
Green1995SVX's Avatar
Same here.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-05-2011, 02:51 AM
kwren's Avatar
Same here.
Dito! That was the reason for my confusion. why would it be necessary. I always just do it the same way. Just wanted to make sure I wasn't missing something there! Thanks!
Keith
Old 11-05-2011, 07:01 AM
Im just a stickler for detail and have quite a collection of svx specific engine tools and was lpoking to add to it.
Old 11-05-2011, 08:44 AM
Cam Cam is offline
That tool is pointless, and a waste of money. The crank pulley bolt is the best option. I don't see any need to stress the woodruff key more than necessary.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
