adjustable dampers
I was in the process of prepping the motor for a pull and i noticed that the front dampers appear to be adjustable.
I didn't see too much on line when I searched. Should I assume these are Koni with eibach lowering springs? |
Re: adjustable dampers
If you post a picture of them it will help.
Koni's strut bodies are yellow by the way.
The wheels are held on by splined tuner lugs.
Which did not come with a key. Ill have to find a key first |
Just take a quick pic of what you can see from the top.
Pretty low ride height for an svx. |
Any thoughts as to the brand?
