Old 12-18-2007, 01:02 PM
nextse7en's Avatar
nextse7en nextse7en is offline
Graphic Artist
A quick speed table for those with 4.44s
Just so you know, a bit of research has yeilded the following numbers for 4.44's
When your car says________________________You are actually going.
10mph -------------------------------------------------9 mph
20mph-----------------------------------------------18.2mph
30mph-----------------------------------------------27.3mph
40mph-----------------------------------------------36.4mph
50mph-----------------------------------------------45.5mph
60mph-----------------------------------------------54.6mph
70mph-----------------------------------------------63.7mph
80mph-----------------------------------------------72.8mph
90mph-----------------------------------------------82.9mph
100mph------------------------------------------------91mph
110mph---------------------------------------------100.1mph
This assumes you got your tranny out of an outback.
In other words, you are travelling 91% the speed indicated, or 9% slow
Please update your brain accordingly.
-Patrick
Patrick
1995 Ebony Pearl. S.N. 0001 "Araby"
JDM Power Mode Switch, Integrated GPS/Video Player
6Xk Miles.
1992 Teal - Sold to Mysvxrocks
[SIGPIC][/SIGPIC]
Old 12-18-2007, 01:04 PM
94SubieSVX's Avatar
94SubieSVX 94SubieSVX is offline
OOC for a while
Send a message via AIM to 94SubieSVX
What would be the difference if you have a stock 4EAT with a 4.44?
bLAh
Old 12-18-2007, 01:14 PM
nextse7en's Avatar
Graphic Artist
No idea, depends where your diff came from. If it came from an outback, probably exactly as the table above. The speed sensor essentially reads axle speed, but the speed is calculated based on a taller (outback) tire. Since ours is not so tall, we get a speed discrepancy.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 12-18-2007, 01:19 PM
94SubieSVX's Avatar
OOC for a while
Hmm...well when YT did it, he swapped the SVX speed sensor in, is that table based on an Outback trans with the Outback speed sensor? Or SVX Sensor?
bLAh
Old 12-18-2007, 01:25 PM
nextse7en's Avatar
Graphic Artist
I am also running the SVX speed sensor, but the gears are a different diameter, and so rotates faster in the diff, which throws off speed, regardless of the sensor.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 12-18-2007, 02:11 PM
94SubieSVX's Avatar
OOC for a while
Ooooo...good to know. Now I don't have to worry about going just over the speed limit anywhere
bLAh
Old 12-18-2007, 02:12 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I use my GPS to see what speed I'm travelling at, and my speedo generally reads roughly 3 mph faster than the actual speed.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 12-18-2007, 02:18 PM
nextse7en's Avatar
Graphic Artist
Just so everyone knows, I figured these out on paper, then took a stopwatch and my car out on the freeway to verify, these numbers are solid.
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 12-18-2007, 04:21 PM
PDSides PDSides is offline
Old Guy
So, if you run larger diameter wheels and tires you could negate the error caused by the 4.44s. It takes a bit of math, but if you persist you should arrive at a combination that makes the speedo spot on. A case where you add a new problem in order to solve both!
Preston
Old 12-18-2007, 06:07 PM
cruisen_15's Avatar
cruisen_15 cruisen_15 is offline
i think i have stock gearing... but my speedo is off by 5mph... lol i always check it with the speed radars and ill be doing 25 in my car and look up at the screen and its like 21 or 20....
Old 12-18-2007, 06:55 PM
Am I missing something here?
I thought it was off by 5.5%.
The way I see it is that the speedometer reads only axle rotations.
So if the speedometer is reading axle rotations, and the transmission "expects" a 205/70/15, but actually gets a 225/50/16, a slightly shorter tire the speedometer should read a little high, (5.5%) as the SVX is not travelling as far as it would, if it had the expected (taller) tires on it.
Old 12-18-2007, 08:12 PM
nextse7en's Avatar
Graphic Artist
Ohh, lemme at that web site.
May have something to do with the fact that I am running 215/45/17"
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
Old 12-18-2007, 09:05 PM
http://www.subaru-svx.net/photos/user.php?LarryIII|14766
Compliments of LarryIII's locker. I use it all the time. Thanks!!!
Old 12-18-2007, 09:41 PM
Yes! Thank you Larry!
Old 12-19-2007, 12:59 AM
nextse7en's Avatar
Graphic Artist
Hmm... even with the values I entered, it still doesn't explain for the inaccuracy.
Something else is afoot here, gentlemen.
I my odometer reads precisely 1.09 miles per 1 mile. No matter what, no matter what mile marker. Or one minute, 6 seconds per mile on the stopwatch, when the speedo shows precisely 60 mph no matter what.
Possible causes anyone? Only started happening after the 4.44s were installed.
-Patrick
Patrick
6Xk Miles.
[SIGPIC][/SIGPIC]
