Old 12-20-2010, 09:31 PM
Nevin's Avatar
Nevin Nevin is offline
4.11 VTD tranny swap video
Ok all, here's a video of me doing a run after the 4.11 swap.
Now, I still consider the swap a success, but it's not all sunshine and lollipops at the moment. If you watch the video, it will explain everything.
http://www.youtube.com/watch?v=DFW4sx3excs
Any ideas, let me have them!
Thank you!
Jesus is the remedy
2015 Expedition EL Ecoboost
Ebony Pearl '95 Subaru SVX LSi
Home of the Bontrager Works 22mm rear sway bar!!
Old 12-20-2010, 10:16 PM
Re: 4.11 VTD tranny swap video
Man that thing shifts quick, although I haven't even been in my SVX for a month or more, and it's been quite a bit longer since I stomped on it at all, so my memory may be a bit hazy.
Old 12-20-2010, 11:01 PM
That sucks man. At least my car is predictable (only 2nd gear and reverse), lol. That's just weird.
What TCU are you using?
Old 12-20-2010, 11:27 PM
Nevin's Avatar
Yeah, it shifts way quicker than before. I'm running the ECUtune valvebody upgrade though, as well as his TCU upgrade.
The TCU is in fact a JDM SVX unit that I scored off of ron (needforspeed). I have othe tcu from the wrx that the tranny came fromn, but per the advice of LAN and a few others, I'm running the SVX unit instead.
Do the JDM svx's have the dropping resistor wired the same way as the usdm units? That's one thing that's crossed my mind.
Jesus is the remedy
Old 12-23-2010, 12:23 PM
Nevin's Avatar
Yeah so I feel...what's the word? Oh yeah, retarded. I feel retarded.
I just realized this morning that I used the TCU from the WRX instead of the TCU that I had ECUtune burn me. That would probably explain the "having no idea when to shift" thing, since the wrx would have used a cable speedo, and therefore the TCU wouldn't have the same capabilities as ours.
I suspect that's the problem. I'll get around to it tonight and then make another video.
Jesus is the remedy
Old 12-23-2010, 01:28 PM
Yea that would probably do it.
Old 12-24-2010, 07:43 AM
longassname's Avatar
Just some dude.
Significant Technical Input
It has an ECUtune valve body.
Old 12-24-2010, 10:00 AM
Geoff's Avatar
Geoff Geoff is offline
Send a message via ICQ to Geoff Send a message via Yahoo to Geoff
Do a writeup, Nevin. Very interested in doing something like this later.
Old 12-24-2010, 11:39 AM
Nevin's Avatar
Geoff, there is a more thorough explanation in another thread I started.
http://www.subaru-svx.net/forum/showthread.php?t=56203
Jesus is the remedy
Old 12-24-2010, 02:36 PM
Nevin, job well done, congrats! After viewing your youtube video I noticed what appeared to be a check engine light/stop lamp light, light up...any ideas as to what is causing this? Couple of additional questions
1) Do we have any indication that this particular tranny is any more durable than a stock svx transmission?
2) I am bit confused as to what mounts were the issue...was it the 4.11 transmission or the differential? Does the 4.11 transmission use stock svx mounts?
