http://www.raceconcepts.net/list.php?section=rotor
Hmm so I have been calling race concepts for over a week now, leaving a voicemail everytime, and they still havnt responded back. Anyone else get ahold of them?
With the changes to our computer/network thingie at home, I had actually NOT E-Mailed him so when Di sent out my E-Mail he called right away. If you guys want me to, I can stock up on his SVX rotors/pads/ SS lines and you can get them from me.. On monday I'll find out what sort of discounted price I can get/give. More later, Tom
I'll eventually get some if you decide to stock up...I want some fancy breaks and row-ters
bLAh
Hooray for Tom possibly becoming a distributor
I have FrozenRotors on my car. Have to say that they are good. Use them with Axxis Ultima pads. Good combinatino. SDeen me thru a number of tracks days.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
ps. How would I know if my rotors are warped? Paul. |
If you have a dial indicator with a magnetic base, then you can remove your wheels and tires, reinstall at least three wheel nuts per rotor, and check for warpage that (the correct) way. The discard thicknesses for the front and rear rotors are; 1.024" front, and 0.335" rear.
I am going to be able to sell Race Concepts Dimpled, Slotted, Plated Rotors, (sets of four) Pads, (for all four wheels) and Stainless Steel Lines for $375.00!!! Shipping will be through DHL, cheap and insured. Or you can pick them up here. More later. Tom
You're officially my hero! At that price I'll be getting in touch with you about a full set in a couple weeks! You may want to start a new thread like the HID for SVX thread for sign ups and ordering. I think you're going to have a lot of orders. You may have to build a small warehouse if this distributing thing goes much farther.
http://www.subaru-svx.net/photos/fil...BABY/4388.html |
#28
WOW, ok so new brakes on on the "soon to come" list now
bLAh
#29
Ditto.....
This month, wheels and tires. Next month, rotors and brakes
Verified Females |
#30
Paul 1969 Corvette 1995 SVX L Safety Option Package, HID's & Awsome Braking (Svxfilies/TomsSVX), JDM Clear Corners, JDM Boxer Engine cover, Transmission Cooler, AND NOW JDM FOLDING MIRRORS! 1995 Corolla 2003 Highlander |
