Old 02-11-2009, 04:22 PM
taylorbr's Avatar
taylorbr taylorbr is offline
Cheapest/Easiest Way to get to ~400 crank HP
I'm looking at pulling my engine to repair some leaks and am considering rebuilding it in the process. I curious what the easiest and/or cheapest way is to get around 400 HP at the crank and still be streetable? Is it an N/A build with larger displacement and higher compression or FI either by a turbo or supercharger? Appreciate your inputs, thanks!
'93 Legacy LS (will last longer than the cockroaches)
'94 SVX LSi
Old 02-11-2009, 04:49 PM
Mensaf's Avatar
Mensaf Mensaf is offline
What do you mean wrong SVX?
Re: Cheapest/Easiest Way to get to ~400 crank HP
Supercharger setup will get you there. Jersey Tom is selling his for 5g's I believe. If you're really going to spend money on it, get the block built/prepped properly for it, and make the switch out of the non interference heads.
Old 02-11-2009, 05:45 PM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
OT selling supercharger set up's too as far as I know.. From what I understand, almost all superchargers, especially ones capable of getting you to 400HP, require additional maintenance and upgrades which result in plenty of cash spent.. Like over 7 grand worth...
Old 02-11-2009, 07:39 PM
intellibomb's Avatar
intellibomb intellibomb is offline
do a search for a brighton impreza with an eg33 swap... he was using it as a track car but he was getting ~400 hp NA....
Old 02-11-2009, 07:52 PM
Easy and cheap are kind of relative at that point. It's do-able N/A, but not easily. High compression pistons, serious headwork (port/polish and custom cam/valve setup), exhaust, and engine management to start.
Alternatively you could go with a bolt-on supercharger, although there's only a couple available out there. TomsSVX could probably be convinced to part with his setup, but again not cheap.
Either way I'd say your minimum cost will be $6-$7000. Not trying to discourage you, but it is expensive to get power out of these motors.
Old 02-11-2009, 07:57 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
I don't think there's much "streetable" about that setup!
Old 02-11-2009, 08:03 PM
Here's the most recent thread about that car. It was putting down 292 AWHP (~380 crank HP).
Old 02-11-2009, 08:22 PM
RallyBob's Avatar
RallyBob RallyBob is offline
Registered fabricator
Actually, that's the old thread. It was updated here. It's now making 318 whp/276 wtq on a different dyno (which reads about 10% lower than the old one). Regardless of the 'actual' numbers, it is considerably faster now.
Bob Légère
EG33 Impreza tweaks
Old 02-11-2009, 08:26 PM
RallyBob's Avatar
Surprisingly it is pretty docile, all things considered. The recently increased displacement has actually made it tamer to drive. Don't get me wrong, the lack of inertia would be hell to drive in a full weight SVX on the street in stop and go traffic, but in a lightweight Impreza it pulls right off idle cleanly...although the idle is at about 1100 rpms. But other than the (much) louder exhaust note there's really nothing 'unstreetable' about it in an Impreza chassis. The hard part would be keeping your license.
Bob Légère
EG33 Impreza tweaks
Old 02-11-2009, 09:28 PM
LetItSnow's Avatar
The exhaust was the first thing that came to mind. The rest I can't speak for, but I'll bet you're right.
Old 02-12-2009, 12:25 AM
Originally Posted by taylorbr View Post
I am curious what the easiest and/or cheapest way is to get around 400 HP at the crank and still be streetable?
Small block Chevy!
300 HP is much easier.
Old 02-12-2009, 07:47 AM
taylorbr's Avatar
Small block Chevy!
, thanks for that! I was reading about Bob the fabricator's efforts at N/A builds and I know those get to around 400 crank HP. I was just trying to get a feel for the differences in cost and streetability between something like that and a supercharger...
'94 SVX LSi
Old 02-12-2009, 08:11 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Small block Chevy!
And sooooooooo much cheaper.
Old 02-12-2009, 08:35 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
Actually, I think that exhaust sound is very tinny and crappy. I think the stebro type sound is sooooo much better.
Lee
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 02-12-2009, 10:58 AM
RallyBob's Avatar
IMO, the easiest way to get 400 crank hp (or 400 whp for that matter) is to go turbo. A single turbo would be easiest to fit, and something like a GT3076, a 'small' GT35, or a GT3782 (cheaper, non ball bearing) would easily produce the numbers and spool nicely. You could run lower boost to extract the same power if you 'freed up' the engine's breathing a little too. Mild head work and cams would compliment things immensely.
Pay someone to do it and it will always cost you. People don't work for free, nor should they be expected to. But if you're capable of doing all the work yourself you could probably put it together for about $8500 or so.
Bob Légère
EG33 Impreza tweaks
