Old 07-12-2011, 05:29 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Question sputter sputter run die
bout a week ago i was driving around and my car started to sputter and have rough idle...i thought it was running on fumes so i filled up at the gas station..it fires right up and i thought all was dandy. well the other i started it after driving 30 min and it had rough idle again so i gave it some gas and it smoothed out to normal. i drove back home and let it sit for awhile before i went to work and it would not start. it cranks over so its not the battery...any ideas? i tried it again today and did minor trouble shooting and looked at the forum but nothing popped out at me. injectors? fuel pump? spark plugs?
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 07-12-2011, 08:02 PM
Re: sputter sputter run die
MAF.Most likely.
Old 07-21-2011, 09:09 PM
VICSVX's Avatar
Never Forget
I checked that by replacing one I have in my other svx...still no start...any other ideas?
VICSVX
Old 07-21-2011, 10:12 PM
Coolant temp sensor, fuel pump
Have you tried checking the codes?
Old 07-22-2011, 12:45 PM
VICSVX's Avatar
Never Forget
NO I haven't checked codes due to time lol but ill look. Any way to check the fuel pump without takin it out lol
VICSVX
Old 07-22-2011, 02:04 PM
XT6Wagon XT6Wagon is offline
clean your battery cables at both ends. The terminal connections also need to be taken off the end of the cable and cleaned as there is almost allways corrosion in there. Last if the body ground is super rusty like my car is, might think about adding a new body to engine ground wire somewhere else.
This fixed my SVX's stalling issues. If it doesn't fix yours, atleast you will have any grounding issues messing with your testing of the sensors.
Old 07-26-2011, 05:13 PM
VICSVX's Avatar
Never Forget
so your car did the same as mine? i replaced fuel filter and now in the middle of taking fuel pump out. i'll try cleaning post while im at it...anything else to try?
VICSVX
Old 07-26-2011, 08:45 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Yes, again, did you check your codes...when the car idles rough, that should kick the CEL light on your dash. Mine did that when my IACV went funky.
1995 Subaru Svx L / AWD
Old 07-26-2011, 08:54 PM
VICSVX's Avatar
Never Forget
well i cant even get it to run now lol once i get it that far i'll do that but right now having issues getting her to start
VICSVX
Old 07-27-2011, 04:45 AM
msvx95's Avatar
It's just a phase
Here's a quick how-to for checking codes...you don't have to start the vehicle or have it run.
The "Check Engine Light" indicates transmission codes. Long blinks = 10, short blinks = 1. In other words, two long and two short blinks is a code 22. One long and one short is code 11.
The following self diagnosis will show any fault codes for the engine:
Remove the kick panel just beside the left foot rest on the driver's side.
Locate blue wires.
Locate black connector (smaller of the 2 black ones). Hold it notch up.
With ignition off, insert one of the wires into top row, 2nd pin from left.
Turn key to on position, but do not start the car.
Count the blinks from check engine light on dashboard.
Old 07-27-2011, 11:23 PM
yah my car had
hard starting
rough idle
random stalling at idle
stalling shifting between gears
you could usualy get it to stay running if you kept it at 1,500-2,000rpm. But that gets old quick even just doing it to move it between parking spots around the property.
Old 07-31-2011, 02:57 PM
VICSVX's Avatar
Never Forget
So I replaced the fuel filter with no dice. So I decided to take the plunge and R&R the fuel pump....and bingo.
Thanks for all the advice guys
VICSVX
Old 07-31-2011, 10:53 PM
Nicely done, sir.
And thanks for posting the solution. Many times people forget to and that makes searching the forums (years later of course) fruitless.
Old 08-02-2011, 09:15 AM
VICSVX's Avatar
Never Forget
Nicely done, sir.
thanks lol I know what you mean...been through many unfinished threads:/ removing the pump was a little tricky but doable with patients..same with install lol
Now to the trans:/ lol its always sometí
VICSVX
