Old 04-23-2012, 08:25 AM
alia176 alia176 is offline
Slight engine missing when the head lights are on!
This is a new one for this car. While I'm sitting at a red light, if I turn on the side marker lamps or headlamps,, the engine starts to miss. Not bad enough to stall the engine by any means, but you can feel and hear the hiccups. Turn the lights off, everything is silky smooth.
Obviously, a possible short somewhere but has anyone experience this before? If I recall correctly, this is similar to the crankshaft position sensor doing something similar. The shielding on this wire is exposed so perhaps an EMI is being created? Just a shot in the dark!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 04-23-2012, 09:28 AM
Mr. Claret's Avatar
Mr. Claret Mr. Claret is offline
Re: Slight engine missing when the head lights are on!
Don't overlook the possibility that you battery or your alternator is weak. Free 'load' tests can be attained at most auto parts store (i.e. Autozone, Advance Auto, etc.)
You may also want to double check that the TPS is properly adjusted. I know when I turn my lights on, typically when cold, RPMs fluctuate quite a bit sometimes.
Just my $.02
- Sonny
[1992 LSl, Claret 160k] / [1992 LSl, Dark Teal #378 172k] / [1992 LSl, Claret 150k] / [1992 LSl, Liquid Silver donor] / [1992 LSl, Liquid Silver 4.44] / [1997 LSi, Polo green #089, 150k]
1992 Chevrolet Lumina Z34, white 35k miles
1992 Chevrolet Lumina Euro, charcoal grey >200k (first car)
1992 Chevrolet Lumina Euro, charcoal grey >200K (for sale)
1986 Honda VF500F Interceptor
1994 GMC Jimmy S-15
Old 04-23-2012, 09:37 AM
A dying alternator will produce all sorts of weird symptoms in our cars. Mine was misfiring, making thumping noises from the stereo, and could barely drive forward. Definitely take a look and see what sort of voltage it's outputting under load.
Old 04-23-2012, 01:00 PM
Check your grounds also. Battery -> chassis and chassis-> engine. The chassis ground is on the horn bracket in front of the battery. The engine ground is on the engine block somewhere near the starter.
Old 04-24-2012, 06:57 AM
Had the charging system checked out and all is good.
The intermittent issue has gone worse by the end of the day. Now, she misses while idling with or w/o an electrical load turned on. I even felt couple of hicckups while accelerating as well.
Looks like the miss is being caused by spark escaping out of the spark plug coil, cyl #1, #2 or #3 is the culprit. I can hear a spark jump and see the engine miss. I bet one of my spark plug coil housing is probably cracked and causing the spark to ground out.
Will check the ground today, thanks for the suggestion.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 04-24-2012, 05:55 PM
Yes thate sounds like the cause, the coil may not be cracked, just have a burnt track down the side, that can be scrached out and sealed with silicon spray.
Old 05-18-2012, 06:12 AM
*** update **
Well, it turned out that #2 ignition coil (middle, passenger side U.S.) was the culprit. Swapped it out with a brand new unit and all is well.
I'll replace all plug coils eventually as they have around 150k miles on them.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
