Old 01-17-2012, 10:27 AM
Huskymaniac's Avatar
Uses the ignore feature
My car fixes itself...
sometimes!
Case 1: Last winter was my first winter with the car which had spent its life in TN and GA. When the weather got cold I noticed the idle would bounce a little when I started it. It would eventually settle but it would undershoot and overshoot the desired idle a couple of times. This happened more if the car had been driven a couple hours earlier versus sitting overnight but wouldn't happen if, say, I just stopped to get gas. Well, this winter the problem seems to be gone. I did get the valve cover gaskets and PCV changed late last winter/early spring. Regardless, somehow the problem seems to have fixed itself.
Case 2: Yesterday the "Brake" light was on when I started the car in the morning and stayed on until I got to work. I never use the emergency brake, as I rarely park on a steep incline, and it still seems tight. When I got to work I turned into my parking space (right turn) and the light went off and stayed off.
Now, if only the rattle noise in the front would fix itself and stayed fixed, as well as the #3 O2 sensor that comes on about once every 3-4 months.
Tony
Old 01-17-2012, 10:59 AM
Re: My car fixes itself...
Your brake master cylinder has a switch in it for when the brake fluid gets low, that makes the e-brake light come on. Open the cap and see if the rubber thingy inside the cap is popped out, where it would push the floaty thing down to hit the switch, or the brake fluid is low. The "brake" light serves both purposes.
Old 01-17-2012, 11:33 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
So that's why my brake light comes on from time to time... I thought that thing was supposed to be popped out...
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 01-17-2012, 01:53 PM
LastSVXintheChi's Avatar
LastSVXintheChi LastSVXintheChi is offline
Send a message via AIM to LastSVXintheChi
mine fixes itself too!!
every once in a while my check engine light will come on for no apparent reason then it will shut off either by itself or when i shut the car off and turn it back on!
these cars are special
Jared
1992 dark teal SVX LS
Old 01-17-2012, 03:54 PM
Mr. Nosidda Mr. Nosidda is offline
#3 o2 sensor? I was under the impression the SVX only had 2 of them
Old 01-17-2012, 04:23 PM
dragoontwo dragoontwo is offline
Why #3 O2 sensor? Because OBD-II.
'92 SVX LS Pearl White - 6mt
Old 01-17-2012, 07:29 PM
wohnson89's Avatar
wohnson89 wohnson89 is offline
At home in the flatland
Thank you good sir! I have that same light on my dash,and I thought that it just meant that my e-brake was on. I know where I am going tomorrow...
1992 Subaru SVX LS-L Pearlie
1989 Mazda RX7
2005 Mini Cooper S
Old 01-17-2012, 08:17 PM
http://www.subaru-svx.net/photos/use...svxfiles|42164
Kids.
Old 01-17-2012, 08:23 PM
What would cause the cap to get pregnant?
Tony
Old 01-17-2012, 08:47 PM
How does that "ignore" feature work again?
Old 01-17-2012, 08:49 PM
OR, because your reservoir cap is "f---t up!
Old 01-18-2012, 01:28 AM
jeffs92svx jeffs92svx is offline
When it is real cold my engine light will come on when i start the car up and rev up and down and will die. It hasnt done it for a while now but the last time it did it I reved it real high and it went off and hasnt been back on or run erratic. My codes when the light was on was for the bypass control valve and 2 o2 sensors. I think maybe it had something gummed up in a vacuum line maybe and the rev blew it out.
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS
Old 01-18-2012, 12:56 PM
gbianchi gbianchi is offline
OK I'll play, my pearle has a check engine light after a drive and shut down then restart, but if I pop the hood after a drive and "check the engine" then no light. Then the other day went for a drive and the only part of my front wiper switch that worked was mist, where you pull it forward for 1 swipe, oh great I thought, now we are a fair weather car! After driving for awhile I turned to the high setting and left it there, bingo started working correctly. Ya these cars are SPECIAL alright......G
03 Baja. 05 Baja turbo
92legacywagon"snow"
94legacywagon"whinny"
84Brat"huey"
92svx"samantha".pearl
92svx"sabastian"4.44 silver
92svx"sabrina".ebony
06 Subaru legacy gt limited.
Old 04-18-2012, 10:22 AM
Does the pregnant master cylinder cap need to be replaced or is it ok to just "pop" it back down?
Tony
Old 04-18-2012, 10:59 AM
processengr's Avatar
Ok to pop it back down. The bellows helps keeps moisture absorption by the brake fluid down.(when it is working correctly)
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
