Old 03-10-2011, 10:21 AM
What do the two tiny little vacuum lines off the throttle body control?
Those two tiny ones that sit on the throttle body runners, with 90 degree bent outlets. I know one controls the EGR, but where does the other go?
My throttle body is being cleaned up in preparation for joining the new manifold I'm making, which includes shaving all unnecessary details. The new manifold won't have an EGR inlet, so the vacuum source is going to be sliced off, plugged, and smoothed down.
I would just go look at my car, but it's under a cover and a foot of snow.
Old 03-10-2011, 10:39 AM
Re: What do the two tiny little vacuum lines off the throttle body control?
QQ: Would just plugging the line cause the EGR to stop working? Effectively deleting the EGR?
If I get a chance later I'll take a look at one of my spare engines to see where those two lines lead for you.
Also I'm going to go ahead and guess you know how to delete the charcoal canister, right? I already did if you need info.
Old 03-10-2011, 11:48 AM
The problem is I don't know what circumstances trigger the EGR to open. Removing vacuum may lock it open full time, as opposed to closed. Mine will have a small block-off plate on the outlet that normally connects to the manifold.
I'll be ditching the canister but keeping it's vacuum source on the throttle body to pipe into my vacuum manifold, which in turn distributes it to whatever I want. The return line I'll just plug and hide away. I'm also opening up the electrical harness that lives under the intake manifold and re-routing the wires to tuck them away a little better, as well as replacing all the nasty old wire loom with braided sleeving.
Old 03-11-2011, 10:44 PM
Bump for answers? I'm itching to get the cutters out...
Old 03-13-2011, 07:10 PM
Mitchell On Demand (Or Snap-On Shop Key, same thing) shows that both lines are used for the EGR, so.... *gets tools*
Lines and nubs are now cut off and smoothed down. I'll be making or finding something to press into the holes to plug them permanently.
Old 03-13-2011, 10:09 PM
Followed the lines this afternoon and it looked to me like they were both for EGR as well. One of them leads to an electrical thingy under the plenum first, one goes straight to the EGR thingy.
