Old 11-07-2007, 09:16 AM
pavanbabut's Avatar
Originally Posted by TE1221 View Post
Now I'm all ears if someone can make our reverse lights brighter
As others said, just get some high wattage bulbs for reverse, brake and turn signals if you want more light output (but its definitely gud for reverse lights, as stock ones are way dimmer). Checkout danielstern's webpage, he has a large collection of name branded bulbs (little pricey though in some cases). But you can find some high wattage bults at any autostore.
-Pavan.
Old 11-07-2007, 01:49 PM
NiftySVX NiftySVX is offline
I dont think that would be feasible due to the warm-up time required from the HIDs. I don't think that anyone uses their blinker enough to benefit from the added output that you can effectively achieve by coming up wtih an LED solution.
I am talking about cornering lights, not blinkers. They would be on steady when the signal was on. I almost did this by installing amber 1194 bulbs on the outer side of the waterfall, and adding a relay to switch the two corner lenses on when there was power to the flasher.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 11-07-2007, 09:20 PM
I am in the process of a unique headlight wiring mod. This involves cutting power to the headlight relays, through a separate switch, while the column stalk is in the normal headlight position.
When I turn the headlights on, via the column switch, my HID headlights come on and I can turn on my HID fog lights as well. If needed, I can use the separate switch to cut power to the headlights, leaving me with the ability to drive with only HID fog lights (which is plenty)
With the lower beam pattern of the fog lights, I should be able to drive in snow without distracting oncoming drivers. As a test, I blocked off the HID projector bulbs to see what the output and beam pattern was for the HID fogs, and it was more than adequate!
When additional light is needed, I can either turn the headlights back on and turn on the high beams, which disconnects the fog lights.
This mod involves cutting one small red wire and is easily reversible.
Old 11-14-2007, 07:44 PM
Henry, 9006, 4300K HIDs went out today!
Thanks again.
Old 11-14-2007, 07:49 PM
bought a set from Tom last meet at his place, these things are sick and highly recommended
Old 11-14-2007, 08:28 PM
If they are sick, why are they highly recommended???
I think they are great and highly recommended.
Old 11-14-2007, 09:24 PM
94SubieSVX's Avatar
OOC for a while
Yeah these are pretty bright. At least once a day I get somebody flashing their lights at me thinking I have my highs on.
bLAh
Old 11-15-2007, 08:51 AM
Seraphinwolf's Avatar
Seraphinwolf Seraphinwolf is offline
H6 THE ONLY WAY!
Send a message via AIM to Seraphinwolf Send a message via Yahoo to Seraphinwolf
You realize thst's not a good thing cause you can get pulled over by the cops if they think you have the highs on. Besides I got that just wiht Silver Stars and my fog's on.
94 Bordeux Pearl LSi (Jun 2009) 109k Plate:GADDIS
What they call it a vanity-plate. Shouldn't I be obligated to be vane with it?
Rota Tarmac 3's 18x8" on 245/40/18 Dunlop SP Sport 600's, Perrin light weight crank pulley, PRW radiator, custom coilovers(not GC's), 9006 HID 4300k 50W low beams, DIY garage door lip, and SVXfiles brake kit. Fixxed exhaust so no more sweet sound.
97 White/Black trim Impreza Outback Sport (March 13/08) 150K-180K(sensor broken)Good news is EZ30R and 05' 6speed full powertrain swap is in motion!: Will be doing more work as I can. Gonna be run by a Hydra so yeah fun to be had.
[SIGPIC][/SIGPIC]
-Gaddis
Old 11-15-2007, 09:14 AM
sicksubie's Avatar
My 5k's are absolutely great....
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 11-15-2007, 12:19 PM
94SubieSVX's Avatar
OOC for a while
Well, I don't think I should be driving with my fogs on all the time as well
bLAh
Old 11-15-2007, 12:22 PM
It's Just Eric's Avatar
Missing in action
So.....Who's gonna be the first to make HID high beams?
R.I.P Cool Signature.
Old 11-15-2007, 12:31 PM
94SubieSVX's Avatar
OOC for a while
OT did that already
bLAh
Old 12-11-2007, 05:53 PM
Has anyone noticed the HB3 and HB4 castings into our bottom of the lenses in our headlight assemblies? The outer edge of each headlight assembly says HB4 (9006 bulbs) and around the middle of the lens is the HB3 lettering (for the 9005 bulb)
True OEM projector HID systems have "HID" cast into the lenses instead. A really savvy (and anal) law enforcement could make a case for their removal from our cars, as the lenses reveal the legal bulbs. We just can't say "This is how they came"
Here are some extreme close-up photos of these markings. The slight amount of "grainy-snowy" stuff on the inside of the lenses is the disintegration of the edges of the projector lens from friction and vibration inside the housing where they are mounted.
I may buy a NEW set of headlights. I would then take the current headlight assemblies apart (using the oven method), mark the position of the projector lenses and take them out of the housing. vacuum and clean all of the debris thoroughly from the housing and then re-bed the lenses, using a bead of silicone around the edges to seal and cushion the lenses from vibration, eliminating this problem in the future.
Or I may hold off as my sister is going to Germany in March for two weeks on business. If she can score a used or new set of glass headlights, I would still take them apart and put the glass lenses on the US housings (to keep our bulb configuration and the fog lights)
Old 12-11-2007, 08:15 PM
pavanbabut's Avatar
both my Alfas work like that. When you switch on the headlight switch to parking lamps position, you can switch on both (front/rear) fog lights. I use front fog lights most of my commute time, when there is light light outside rather than using headlights all the time.
-Pavan.
Old 12-11-2007, 08:27 PM
HID's in snow
I had my first experience today driving at night while it's snowing. We got a good dump tonight, during my drive I would say the white stuff was coming down in moderate heavyness. No blowing. I didn't notice any particular adverse effects from the HID's. The 6000K definitely produces a blue tint on the snow, but there was no more hindrance to visibility than with normal hologen bulbs. Switching to high beams reduced visibility.
One thing I did notice is that the spot where you can see the light in the snow flakes the most is about 5' about the front bumper, not in front of the car where I would expect to see. Maybe this is just because of the angles involved with the reflection. Turning the high beams on moved the bright spot higher up.
