Old 05-03-2009, 12:50 PM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
AIRBAG light... will it halt an inspection?
New Hampshire, if it matters.
Is it typical if the AIRBAG light is illuminated an inspection station will reject?
I tried pulling codes, and I got two long one short, and two short. I think that's codes 21 and 2. Can't find anywhere to ID those codes =(
Haven't really done much to the car before that light came on. It was parked. Nothing hit it. I was running it fine for days. Then suddenly, tada! Airbag light.
I need an inspection!
-sz
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 05-03-2009, 12:57 PM
Re: AIRBAG light... will it halt an inspection?
FROM SVX_COMMUTER'S OLD LOCKER:
AIR BAG Codes (general only, the FSM has more complete diagnostic procedures.)
2 Short in: front sensor harness, Airbag main harness, and module harness, roll over connector, or faulty control unit.
3 Open circuit in: Front sensor harness or front sensor unit.
11 Fuse #8 blown, faulty control unit, open circuit in main or body harness.
12 Roll connector circuit is open, faulty CU, open AIRBAG codes continued for 1992 SVX circuit in main or module harness.
13 Short in Roll connector circuit or main harness or module harness, faulty CU
14 AB2 & AB7, AB3 & AB8, AB4 AB5 AB6 to CU not connected properly.
21 Airbag Control Unit (CU) is faulty.
23 Power supply short in: main harness, Front sensor harness, roll connector. Module harness damaged, Faulty CU.
31 Fuse #16 blown, open circuit in body harness or main harness. Faulty CU.
Light stays ON- light is faulty, harness to light is faulty, ground circuit fault, faulty CU, AB1 & B58 not connected properly.
Light remains OFF- Blown fuse #15, body harness circuit open, light is faulty, main harness is faulty, faulty CU.
Hmmm..... that doesn't sound good. Is it possible trying to jam the Navigation unit in there, it pulled at the Airbag CU harness??? But then, why now, after having it in there for a year......
Old 05-03-2009, 01:19 PM
First, disconnect the battery.
Wait at least twenty minutes.
Remove the drivers airbag, carefully.
Re install it.
Reconnect the battery.
See if the code goes away.
Old 05-03-2009, 01:32 PM
Is that a common cure? Mine's been on since I owned it. I disconnected the little light module for the safety check when I bought it. I changed the CU and the codes changed.
Old 05-03-2009, 03:00 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
I'll be the third with an Airbag problem...So mine has never worked since I owned the car but now want to get it fixed. My airbag light stays illuminated and every time I place the 15a fuse in the kickpanel fuse box, the fuse blows...
so can someone tell me what would be the first thing to look for trying to diagnose this problem? I don't want to have to replace the CU if it doesn't make sense to....is this a harness short problem?
1995 Subaru Svx L / AWD
Old 05-03-2009, 06:15 PM
I've spent eight or more hours checking air bag codes, following the FSM.
After all that I tried the easiest thing possable.
A new air bag.
Twice now that has fixed it.
Just trying to help.
Old 05-04-2009, 07:33 AM
After all that I tries the easiest thing possable.
A new air bag.
Advice is always a gift.
I also realized that my negative battery terminal clamp isn't doing it's job anymore since I had it rigged with a supporting 4 gauge. I've gone out and bought a new post and wire ends and will see if it was a continuity problem. That may also explain to some degree the awful starting issue I've been having, although I think that's far more likely the ignition switch component dying on me.
I need to remove the radio to diagnose a ground hum, so we'll see if the connector the unit itself is not fully seated, and I can do further diag of voltage and resistance between there and the battery. If this ends up being fine, I will give the main airbag a shot.... err, attempt.
Can anyone tell me exactly which metal box in radio area is the airbag CU? Will it be obvious? I've never intentionally looked.
-sz
Old 05-04-2009, 01:43 PM
Blenderhead Blenderhead is offline
I can't say for certain what New Hampshire's laws are, but I know in NJ they don't care about an airbag light, as long as the air bags are physically there. So if the system fails, you don't need to get it fixed, but for example you can't replace the steering wheel with one that doesn't have an airbag in it because that would be disabling a safety device instead of just something that doesn't work that they don't care about.
MY TOYS
95 SVX
98 Lincoln MarkVIII LSC, 5-speed swap
91 Marcury Cougar, 393" stroker, completely insane!
89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt.
80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished.
Old 05-04-2009, 01:44 PM
Check the connector behind the driver's kick panel. My light is coming on because that connector has loosened up. I believe it's a big yellow one.
Old 05-04-2009, 02:21 PM
kwren's Avatar
kwren kwren is offline
If you are in an inspection time line situation, maybe take the bulb out?
Keith
Old 05-04-2009, 03:19 PM
Make sure every time you work on the Airbag system you have had the battery disconnected for at least ten/twenty minutes!!!!!
Old 05-04-2009, 03:41 PM
my airbag light stays lit, but when the outside temps are approx. 70 or higher, the airbag light goes off.
what would this be caused by.
1985 Brat GL 138k
91 CRX Si 40k
91 CRX Si 155k
97 SVX Lsi 70k
2003 s2000
91 RT4WD 166K
Old 05-04-2009, 04:21 PM
Pfffff..What's the worst that could happen?
Old 05-04-2009, 04:30 PM
The airbag deploys at 200 MPH and with your face about an inch away as you reach for some pretty yellow wires it takes your head cleanly off,
or snaps your neck and then dents the roof with your head..
And we don't want no dented roofs.
Old 05-04-2009, 04:46 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
The yellow plug under the kick panel was my problem. I held in together tightly with a zip tie. The light went away for me.
