Old 07-02-2012, 01:24 PM
Re: Crazy_Pilot's 6MT Swap (Lots-O-Pics!)
Originally Posted by Crazy_pilot View Post
OMGWTFBBQSAUCE there are longer bolts?!
Or you can use the shorter bolts, just double the torque spec to compensate
Old 07-02-2012, 01:42 PM
WOW!
You kids sure talk funny!
Old 07-02-2012, 01:45 PM
Normally, Dave, I pull the crankshaft and pesky rear main seal so that I can use both bolts, AND nuts.
Naturally this takes a little longer, but at $50.00 an hour, what do I care.
Last edited by svxfiles; 07-02-2012 at 01:45 PM. Reason: I REALLY hope that youse Guys know that I'm joking!
Old 07-09-2012, 11:48 AM
More progress! Shiny transmission. Less shiny crossmember.
Shifter part way into it's new home:
I think I can now say my car is more manual than automatic.
On Friday I also picked up a set of quarter panels and fenders for the car. So nice to have a beautiful set of factory sheetmetal. One thing I did note is that on one of the fenders there is a bracket which is spot welded in place. However, only one fender has those welds. On the other one it's not welded and bounces around. Anyone else ever seen this before?
Old 08-06-2012, 09:01 AM
'E''s Avatar
'E' 'E' is offline
Round 2: I'll be starting on the swap again tomorrow, but in the meantime I had a little bit of fun with some Brembos.
As YT found out a while back, the mounting lugs on the SVX knuckles are farther out than an Impreza's. The caliper mounts up, but with the added outward push my 17" STi rims don't clear them. Fortunately I just happen to have an 18" wheel lying around...
The stock rotors don't work at all, so I just tossed the wheel on without one. It's a tight fit:
Hard to tell in that picture, but there's about 2mm clearance from the wheel to the caliper. Obviously with a rotor installed that would be better.
Soooo pretty...
i really like this style of wheel
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 08-06-2012, 10:59 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Chris,
Where did you get the quarter panels? I'm definitely in need of a pair for Racer X
The fender bracket is on the passenger's side fender then it's probably for the air intake that feeds up into the airbox.
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 08-06-2012, 11:22 AM
I agree, they fit the SVX really well. I'm not a fan of wheels with 5 skinny spokes, the SVX is better suited to a chunkier design. My wheel is a Rota Grid in 18x9.5" size. The "authentic" version is the Volk/Rays Engineering TE37, but an entire set of Rotas costs roughly the same as a single TE37.
Originally Posted by SVXRide View Post
Chris,
Bill
Hey Bill,
I bought them from Nomad, who was parting out his car and selling his spare bits. I don't know what the availability currently is from Subaru. subaruparts.com showed them as backorder last time I checked.
Old 08-06-2012, 11:30 AM
SVXRide's Avatar
Hey Bill,
Chris,
Mind me asking how much you paid for them?
Thanks.
Bill
Old 08-06-2012, 10:18 PM
'E''s Avatar
'E' 'E' is offline
yeah ive been watching a set on ebay for aud$999 but ive been too busy buying stuff for the brake kits im making
93 black SVX
95 bright red SVX
Old 08-06-2012, 10:19 PM
'E''s Avatar
'E' 'E' is offline
i want the 19s though
93 black SVX
95 bright red SVX
Old 08-06-2012, 10:20 PM
'E''s Avatar
'E' 'E' is offline
whats the offset on yours
93 black SVX
95 bright red SVX
Old 08-07-2012, 06:18 AM
+38 on those wheels.
Old 08-07-2012, 06:48 AM
'E''s Avatar
'E' 'E' is offline
thanks mate
93 black SVX
95 bright red SVX
Old 08-13-2012, 06:55 AM
A bit more progress this weekend:
Block-off plate I made for the transmission harness hole. The clutch M/C requires a 1.25" hole, and the bolt holes are 3/8". It's painted Rustoleum Hammered Black, like the transmission.
With the clutch M/C installed:
Got the R180 and STi axles in:
You can see the slot that has to be cut into the support bracket. The exhaust hanger from the subframe is also in the way. My advice for anyone doing this job: Lift the diff up and slide the studs into the rear bushings, then use a jack to support the front. A 19mm box wrench is prefect to sliding onto the exhaust hanger and bending it. Lift the diff up and bend as required until the bolts go in.
Shifter fully mounted:
And this little pest:
To run SVX front axles the seals in the transmission need to be replaced with those from an early production '04 STi. Only the first 3 months production have the right part. Unfortunately, that part number is discontinued and unavailable to Subaru dealers. My transmission already had the seals changed, but one was damaged. In the end what I did was write down the NOK part number that was on the seal and have NAPA cross-reference it. About an hour and several phone calls later they tracked down a compatible seal across the country. A few days later it arrived in Ottawa. It's slightly thicker than the original seal, but overall seems to fit well.
I also picked up some black Gorilla lug nuts. Better suited to the car's theme than the chrome ones I had previously. They're also aluminum and weigh ****-all. No impact guns!!!
Finally, my method for pushing the car into the garage. I wonder what the tow rating is on an Elantra... Also, RIP to the poor blue Forester... My brother rolled it at ~90 kph last year. Idiot.
Old 08-13-2012, 07:06 AM
dragoontwo dragoontwo is offline
I know it's a bit late to mention it, but the part numbers for the correct seals are here on the site. That is, unless your transmission is different from any other 6 speed. I got the seals for mine direct from Subaru.
'92 SVX LS Pearl White - 6mt
