Uhggg, I think my transmission is done!
Started slipping today and went downhill fast. I'm even wondering if I can make the 4 mile trip home, I had a feeling it was coming but it is still a shock when it happens.
(May be posted in the wrong section, mods can move if so.)
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 Last edited by Sean486; 01-07-2011 at 12:29 PM. |
Re: Uhggg, I think my transmission is done!
No warning at all? Don't you have the cooler too?
Well no, not exactly, it has been flaring a bit. I wasn't really sure if I was having an issue or not so I had been driving it around to try to tell. Today completely removed those doubts. The car did have a cooler but I believe it is the original transmission, although I'm not sure. I'm going out to check to see if the fluid is low or burnt.
I think I am going to try to sell a my Sti BBS wheels and various other parts to try to raise some funds. (Look for a post in the parts for sale soon.)
I have 1st and 2nd gear only.
I know some guys around here who might be able to do your trans if you can come up with one.
how much are you tryna sell your bbs for? their bolt pattern is 5x100 right? or 5x114.3? |
They are already gone, ...I must have had them priced right because they went quick.
oh wow.. okay. how much did you put em out for? just out of curiosity ? |
What cooler did you install and is it in series, parallel or bypass?
This is after a new in pan filter drain and fill earlier in the same year. We also put in 5.5 quarts BG Products ATF in November 2010. Sean did not ignore his SVX!
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 01-07-2011 at 08:07 PM. |
Good luck Sean. I hope you are able to get this repaired at a good price.
Sorry to hear of the transmission troubles.
I bought my car with a trans rebuilt 2 years before I bought it, and a new front diff one year before I bought it, and the damn shop that put in the new diff cracked the plug for solenoid C and didnt even bother plugging it in. I imagine when the pulled they rear housing off they didnt unplug the connector. I just finally got time to pull this apart and replaced the clutches and the solenoid. |
I bought the car 3 years ago assuming that I would eventually have to replace the transmission. It kind of sucks, but was not completely unexpected and I am looking forward to having 4.44 gears installed.
Keep your head up. You are in good hands and better days are ahead.
How many miles? That really sucks man I'm sorry to hear about that. If 2nd gear sticks around then you might still be able to use the car for some time.
