Old 03-24-2007, 02:55 PM
Coilovers for teh BEAST!!
I am returning to my roots within the next couple weeks. I built a set of coilovers for another member recently and I cannot help myself. I order my springs&collars and I am waiting to hear back from Mychailo about the konis... Ah I cannot wait to be back on coilovers I will post pics of the process of building the struts and installation
Old 03-24-2007, 03:13 PM
Soon it will make your sig smaller to only list the stock parts instead of the mods
Old 03-24-2007, 03:24 PM
what stock parts??
tom
Old 03-24-2007, 03:56 PM
Originally Posted by TomsSVX
what stock parts??
tom
Glove box door!
SLACKER!!!
BAHAHAHAHAHAHAHAHAHA,HAHA,HAHA,HA,HA, ha,
snort.
Old 03-24-2007, 04:33 PM
shotgunslade's Avatar
With this mod, you'll be ready to hit the road racing track. Let me know when you want to go, and I'll find an event. First time out, you'll need to go with a group that provides instructors. Probably best bet would be a PDA event at Pocono. Once you get a taste of it, you will be an addict.
Old 03-24-2007, 04:49 PM
sicksubie's Avatar
I think Mychailo is in Japan right now.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 03-24-2007, 05:53 PM
i thought he was going in April?? Crap... do I really need to order them from classic garage?
Old 03-24-2007, 08:41 PM
sicksubie's Avatar
I could be wrong, but I thought he had already left. BTW how much for a set of koni/ GC's?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 03-24-2007, 09:59 PM
coilovers are about 400 shipped and if I get the konis from mychailo they are 630shipped... classic garage is 680+shipping
Old 04-09-2007, 09:01 PM
mbtoloczko's Avatar
sans SVX
I can do coilovers for $400 shipped too. :-) BTW, if you want to get the most out of coilovers, you should get a set of my rear strut mounts that eliminate most of the free play found in the rubber donut on the OEM SVX rear strut mounts.
Mychailo
Visit my locker
Old 04-09-2007, 09:30 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Mychailo,
can you drop me a pm or give me a call about the strut mounts and helper springs? Thanks.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 04-15-2007, 07:48 PM
Had em built for over a week and I just got them installed tonight... Riding 1.5" lower in the front and .5" lower in the rear... rock solid... Rides on rails baby!!! I also kept the stock camber adjustments so I have just the right negative camber I want... All smile here
Old 04-15-2007, 07:50 PM
SVXRide's Avatar
Nice!! No problems with the lower ride height and those 18" rims and tires?
-Bill
Old 04-15-2007, 07:51 PM
no, I was concerned about that but once I let her down.... it looked too damn good to bring it any higher
Old 04-15-2007, 07:53 PM
SVXRide's Avatar
guess you're glad you moved the alternator back up to the top of the engine
-Bill
