Definitely a stupid question.. Axle cap?
Need to re-boot the axle on pass side. Anybody have any good tricks for removing the cap? Tried to pry it off with a lil screwdriver, a chisel etc etc.. No luck, thinking about threading a bolt in to pull it off? What am I missing here? lol
Re: Definitely a stupid question.. Axle cap?
??? a little heat, channel locks ???
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
should just be a matter of tapping it out with a screw driver and hammer or chisel and hammer works well, once you get the cap seperated a little a screwdriver can pull it the rest of the way off. Soak it with lube PB blaster or WD-40 may help. Also don't tap straight down you kind of have to tap from an inside to outside direction. Cap would be pretty replace-able though if you do end up damaging it.
Shotgun???
C4!
I usually start the removal with a gasket scraper, and as soon as I geta gap started, use a screwdriver to pry it off.
Good luck, and welcome
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
GRENADE, IT'LL COME OFF THEN ( or be in such small pieces it wont matter)
William |
I've just used a sharp (alright, maybe a little less sharp now) chisel. I've seen a few at work that were stuck real well, but they all come out in the end, although they're generally so mutilated that they will never be used again.
