#1651
Ah, to be retired and wealthy!
1995 POLO LSI 76K MILES SOLD |
#1652
Can you confirm wether or not these wheels are the same as the infinity bbs wheels?
#1653
Transwheel said this was truly a unique wheel, compared to the hundreds of BBS wheels they have done. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 02-12-2013 at 07:27 AM. |
#1654
Installed the viton o-ring from Subaru on the power steering high pressure line. Hopefully this will finally stop the leaking. The installation definitely felt different as I was tightening the fitting. I think the o-rings I had tried previously were just a little too big on the OD. 0.6mm matters!
Now if I could only find out why my emails on this subject were not returned.
#1655
51 deg today .Gave my 2 babies a bath.
#1656
Just now saw this...
#1657
Bad Tom! Somebody get that man aiPhone!
#1658
OH!
It gets better! I spoke with Di about the missed E-Mails and something server (sever?)was no longer forwarding E-Mailes since FEBUARY THE FIRST!!! sigh. It is working now, Thank you Di.
#1659
exchange server?
#1660
#1661
Finally got around to painting the side mirror I bought to match my car.
These pictures were taken 2-3 minutes after I sprayed the coat so they look kinda rough. I plan to wet sand with 1500-2000 grit paper and then buff with rubbing compound between each coat. So far there have been 4 coats of primer, first 2-3 coats were sanded back down to clean up and smooth out lines left by the old paint (crappy repaint), this is the second coat of color and I plan on spraying 2-3 more and then finish with 2 coats of clear. This is the first time I've tried to paint a high gloss finish and I'm just using rattle cans. But so far I'm pretty pleased with how things are coming along and I haven't really hit any problems that I'm worried about.
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company Last edited by odepaj; 02-13-2013 at 08:08 PM. |
#1662
#1663
I think this is what you meant to say.
http://www.youtube.com/watch?v=m_mDTLphIVY
#1664
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by immortal_suby; 02-14-2013 at 07:08 PM. Reason: swear filter dodge |
#1665
Per our conversation, I looked up o-ring kits and the A011 is a little bigger than the Subaru o-ring. The A011 is 7.65mmX1.78mm and the Subaru is 7.5mmX1.5mm. The OD of the A011 is about 0.7mm larger than the Subaru. I think that is why it had gotten torn. I, unfortunately, replaced it with an even larger o-ring. Once I measured the Subaru o-ring and put it in, I knew why the previous attempts didn't work.
