Old 07-20-2007, 05:07 PM
Mission Mission is offline
Tires on 17 Inch Wheels/Rims
I am going to buy 17 Inch Wheels. I know that the closest to OEM size (225 50 16) is a 225 45 17 but it is slightly larger. I dont like the fender gap on stock wheels and tires. It will be similar with the 17s. What would be the best size to close the gap but not have any issues(rubbing, speedometer, and etc)?
Thanks
Old 07-20-2007, 05:50 PM
Originally Posted by Mission
I am going to buy 17 Inch Wheels. I know that the closest to OEM size (225 50 16) is a 225 45 17 but it is slightly larger. I dont like the fender gap on stock wheels and tires. It will be similar with the 17s. What would be the best size to close the gap but not have any issues(rubbing, speedometer, excess wear on my transmission, and etc)?
Thanks
Fixed it!
Old 07-20-2007, 09:21 PM
Didn't you already have wheels?
I have 245/40 on my 17s. No rub if your struts work. Even less rub if you get less wide tires.
Old 07-21-2007, 08:44 AM
JaySVX's Avatar
JaySVX JaySVX is offline
With 245/45/17 what sort of modifications would one need to do? 245's seem awfully big, what sort of offset are on your rims? I'm guessing you'd need to replace the rear struts/springs and stiffen the suspention, especially if the rear is sagging, which tends to happen quite often.
I have 225/45/17's on my 94, and the gap doesn't look bad. If you want to go larger, make sure you stiffen the suspention, because bumps and rough roads will cause you to run into clearance issues when the springs compress. You could lower the suspention iwth coilovers, but just stiffen it up. This will decrease the ride quality at a bonus of appearance. Personally i love how mine rides, but with the 215's on the front of my teal, they're to narrow and i brake traction when pulling out suddenly from a stop sign, so 245's would be nice if i could find rims iwth the right offset.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 08-14-2007, 02:12 PM
97 SVX 97 SVX is offline
Send a message via ICQ to 97 SVX Send a message via MSN to 97 SVX Send a message via Yahoo to 97 SVX
Tire size
I run 215 45 17 NO problems
That's about 95" circufrence..
NO problems with any systems (speedo etc)
Ian
Ohhhhhhhhh the car handles FABULOUSLY
Old 08-14-2007, 04:29 PM
Tire sizes you can run on a 17" wheel are:
205/50/17, -1% speedo error.
215/45/17, +1% error.
225/45/17, -0.5% error.
235/45/17, -2% error.
245/40/17, +0.5% error.
255/40/17, -0.7% error.
505/20/17, 0.4% error.
Old 08-14-2007, 09:38 PM
Ian
Check your math.
Its more like 77.345945", and shorter than stock.
Just trying to help.
Old 08-14-2007, 10:55 PM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
the 225/45/17 in my pointe are bad bigger would be better cuz we losse some of that body roll and it just makes the car feel different.I all ready have the rims stock 05 sti Gold bbs, tires are going to be the Ecsta SPT size 235/45/17.. right now i have some 235/45/17 but got them use with 30% left so i could of have some fun. so i don't know if the new ones will fit. Also going to put some drop sprring. So is that going to help or be bad. need to know before this week.
