Old 07-19-2011, 12:42 PM
zaueugen's Avatar
zaueugen zaueugen is offline
front bearing
I've just laast week replaced the rear bearings at a mechanic and i told him to remove the packing grease and put new high temp grease in. i hope he kept his word ( dont want them to fall apart after 5k miles)..
my question now is if the front bearings need the same procedure as the rear to install? or is it easier?
Old 07-19-2011, 01:41 PM
Re: front bearing
You should always change the grease on new wheel bearings. The rears are especially unforgiving though. Also make sure they don't overtorque the axle nuts.
Old 07-19-2011, 02:43 PM
Re: front bearing
Fronts are basically the same idea, but the bolts holding the knuckle on are generally more forgiving.
Old 07-19-2011, 04:41 PM
zaueugen's Avatar
Re: front bearing
icingdeath88 i wasnt at the shop when they did it cuz i was working so i didnt get to see if they overtorqued the axle nuts or not, hopefully they didnt. my dad went with the car to the shop and i told him to tell them to take the packing grease off and put new grease in, i hope they did. either way for the front ones instead of paying 400 for both like i did for the back ones im planning on removing the hub myself and bringing it to my mechanic 'friend' to press the bearings out and put them back in.
Old 07-19-2011, 04:42 PM
zaueugen's Avatar
Re: front bearing
btw i called subaru and asked how much the price was to replace the bac bearings ( both) they told me 800$$$ justt the labor !! haha
