Old 08-29-2010, 05:55 PM
ykobayashi's Avatar
ykobayashi ykobayashi is offline
Send a message via AIM to ykobayashi
#6 Spark Plug (Left Side, Nearest the Driver) Change
After a year and a half and mysterious rough running, I broke down and completed the full spark plug change. I did 1-5 but didn't do #6 because it was a daunting looking effort. Plus all the horror stories I heard on the forums didn't help.
I undertook this effort today and completed it. I have to say that this is the single worst thing that I have attempted on ANY car that I have worked on. The stories on the forums don't nearly do this task justice. I am covered in dirt and grease (car only has 61k on the clock) and it only took about 5 hours of fiddling around with that POS to get it in!
On the plus side the car is running smoooooothly and it only took a year and a half!
Lessons learned:
1. Fer Chrissake take the left drivers side tire off! I don't care what anyone says, you can't do this without taking it off. A majority of the work I did from underneath as I could not get my hands into the area from the top and I have smaller hands.
2. There are two plugs in the wheel well, one outer and one inner. The outer one is pretty robust rubber and comes off with a little elbow grease and a flat bladed screwdriver. However, the inner one is flimsy plastic. The published instructions says to take your screw driver and just punch the middle of the plug and it pops out. This is true, but your screwdriver easily goes though the actual plug ruining from further use. Its better to just pry the edge with the screw driver and if you opt to put it back and reuse it, you can.
3. The coil pack and boot - this is a real ***** to get out. Expect to spend several hours fidgeting with this. The coil pack screw deadends against the frame, but don't panic. Just screw it back in a half and inch and use it to wiggle the pack off the spark plug. Once you do this the coilpack will seem too long to remove, it is, almost. One has to jiggle it enough so the head of the coil pack box thingee is pointed towards the driver's cockpit and then lower it down below the engine. I have lost most of my hair as I have pulled it out working on getting just this removed.
4. Removal of the spark plug. Just when you thought the hard part was done, Subaru does this. I was muttering several curse words and colorful phrases in Japanese and hoping that the damned engine and chassis engineer's ears were feeling my bad karma. You have to fish the extension though the hole then mate it up to the spark plug socket which should have the spark plug in it already. This is not easy. Then carefully guide the spark plug onto the threads and start to hand thread it. This will take a very steady had and a truckload of patience.
5. Reinstallation is all this joyous activity in reverse. I did find that putting it back together was a lot easier than taking it apart.
Good luck to you if you are undertaking this effort. If I can help in anyway let me know. Allot yourself 4-5 hours and prepare some very stiff alcoholic beverages afterwards (or during, who knows maybe it will make install easier?)
Yoshi
[B]1995 SVX L AWD - Original Owner
65k - Brilliant Red
Mods: K&N Drop In Filter, Sony aftermarket CD/MP3 Stereo and Speakers, Sumitomo HTR+ Tires
2004 Mazda 6S 5-door - Steel Grey - 5 speed manual transmission - Daily Driver
2011 Mazda CX-9 - Wife's ride
Old 08-29-2010, 06:02 PM
Re: #6 Spark Plug (Left Side, Nearest the Driver) Change
Yes, it's a definate drawback of the boxer engine design. Outback's are not much better, believe me.
Old 08-29-2010, 06:18 PM
Manarius's Avatar
Manarius Manarius is offline
I've done #6 now a few times and I can do it without pulling the wheel off. I have pretty small hands and it takes a lot of finagling but it can be done. I end up having to do it all by feel.
-Jason
-Obi Wan Kenobi
Old 08-29-2010, 06:36 PM
immortal_suby's Avatar
Thread Killah
yep, it's actually easier if you don't look on that plug. Helps to have the right length extensions too.
Locker Link
2015 BRZ Limited 6MT
Old 08-29-2010, 06:56 PM
I have done all six spark plugs on an SVX 3.3 engine in NINE MINUTES!
Old 08-29-2010, 07:04 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Pulled the plugs on the Pearly. 5 were the same.
Pulled the plugs on the junkyard engine I got to follow it. 5 were the same.
My buddy Justin who bought the Pearly actually has six matching spark plugs; I made sure to change them while the engine was out!
OT: How fast with the engine in the car? Tee hee!! Snort!!
Old 08-29-2010, 07:23 PM
You're not actually supposed to back the coil bolts out all the way. After maybe 1/4" you'll feel they're loose from the heads. At this point the coil can be removed. The best tools to have for the job are a 12mm gearwrench (the flex head type is best), and the perfect size extension.
Old 08-29-2010, 07:32 PM
Manarius's Avatar
Speed wrenches would be convenient for getting the coil off. However, getting the plug out requires the good old ratchet (preferably a low profile one) and a 3in extension.
-Jason
-Obi Wan Kenobi
Old 08-29-2010, 08:21 PM
One of my worst experiences was having to replace the #6 coil pack on a dark rainy night, in the middle of a 600 mile trip, with a hot engine...
Last weekend when I changed plugs it took just under an hour for all six, from the top with the engine in the car
But I agree with the OP, for your first time allow a free afternoon...
Old 08-29-2010, 08:32 PM
It sure is good having small girlie hands!
Fixed it for you Dave!
Old 08-30-2010, 02:33 AM
scoobymal's Avatar
scoobymal scoobymal is offline
Never had a problem on my UK car,my hands are normal size,and the car does "NOT" have the access hole in the inner wing
Old 08-30-2010, 07:41 PM
Invisible avatar
Wink Re: #6 Spark Plug (Left Side, Nearest the Driver) Change
The engine was out of the car at the time, wasn't it Tom?
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 08-30-2010, 07:47 PM
Old 08-30-2010, 07:48 PM
Old 08-30-2010, 07:49 PM
Ron.
http://www.subaru-svx.net/photos/user.php?boxer6|19095
