Alternator Belt Driven Turbo? Whadya Think?
http://www.boosthead.com/home.php
Comments, thoughts, idiotic stabs at humor? Could be a good solution for cars without a ton of aftermarket support.
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L Donating Forum Member In Good Standing JDM 4.11 Geared Transmission JDM 'ALCYONE' Rear Panel JDM 'BOXER' Eingngine Cover JDM 'SVX' Hood Badge L-Edition Suede Rear Seats |
would there be space to stick the turbo in somewhere?
the engine bay isn't spacious to begin with....and less space if you have a PWR in there
1992 Subaru SVX LS~L Ebony Pearl 1992 Dodge Stealth R/T Firestorm Red 1992 Subaru SVX LS~L Pearl White 1992 Subaru SVX LS~L Ebony Pearl JDM 6MT/DCCD 2007 Subaru Legacy Spec B. Diamond Grey Metallic |
Belt driven turbo? I thought we called those superchargers...
-Jason (8/23/07-Present) 1995 Subaru SVX LSi (197k) Polo Green (#1102) 03/95 Mods: DDM Tuning 4500k 35w Low Beam HID, 100w H3 Bulbs, Extra Ground Cables, 15 minute $12.96 mod, svxfiles designed transmission mount ( ![]() silver BBS rims, custom power steering cooler (one that doesn't dump ATF constantly), new negative lead cable, no more third or fourth gear ![]() (1977-Present) 1977 Chevrolet Corvette (81k) Silver (12/01/2011-Present) 2005 Subaru Outback 2.5i Limited 5MT (97k) I have a bad feeling about this. -Obi Wan Kenobi |
this apparently isn't a supercharger though...i thought it was weird..
The name "turbocharger" comes from "turbine", the turbine being the blades driven by the exhaust gases. Regardless of what they call it, it's a belt driven supercharger. I think SVXFiles has fit one, or tried one anyway, installing it where the battery is located.
The toy thing in the ad (con), would not compete with a babies fart.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
yeah Svxfiles make the first superchager in a similar set up... called it a super charger... not a turbo... theres a video somewhere on you tube
- John ASE certified Master Tech W/ X1 Twin City Fleet repair, St. Paul, MN need work done? Have tools will travel
![]() We'll make a new video at Reading. ![]()
wow, props to SVXfiles for trying something new. How much do you figure all that ran in the end? How much boost was it able to produce, etc...
![]() I have $82,349.68 in stainless steel bolts and nuts alone. $721.15 in belts, $1182.05 in aluminum angle iron, plus intercoolers, waste gates, boost guages, widebands, laptops, wires, plating, spacers, aluminum 3" tubing, FOUR superchargers, five SC mounts, a wife and the respect of my children....... So far I've seen, actually my son Nick has seen 7psi at 6000 rpm. Note; 7psi on a PORTED engine is as much flow as say, 9 psi on a stock engine. On my last much smaller supercharger, I had 8psi before I ported the engine, and 6 psi after porting. You want air flow, not just pressure. ![]() It's hard to watch guages at 100 on a back a$$ windy road at 7 psi. ![]() j/k about the $82,349.68. ![]() ![]()
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 03-12-2007 at 11:00 PM. |
With that price, he could do almost 20.58742 same set-ups for spares
![]() ![]() Nothing's too fast, Tom. You shld go bed now ![]()
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
