Old 10-05-2011, 07:16 AM
zaueugen's Avatar
zaueugen zaueugen is offline
Re: 9005 headlight upgrade question
ok cool, but i do need the adjustment cables and HID harness, correct?
Old 10-05-2011, 07:31 AM
Shouldn't need these either.
I know of no instance where these were used.
There is enough wire to run from the ballasts to the fog lights without an extra harness. My fog light ballasts are mounted inside the engine compartment away from the engine (towards the front).
One is mounted flat by the A/C evaporator tank, the other by the battery.
Maybe someone who has installed the DDM units can comment.
Old 02-25-2013, 08:11 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
In winter, I often drive with just the fog lights alone without problems.
I was reading through this forum and have a question about how you can make your fog lights work without having your regular headlights on. Is it because you have an HID kit installed that they can stand alone? I have always wanted to do this on my SVX.
Thanks
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 02-25-2013, 08:32 PM
dragoontwo dragoontwo is offline
Thanks
I don't know what he does, but unplug the low bulbs?
'92 SVX LS Pearl White - 6mt
Old 02-25-2013, 09:05 PM
Thanks
You could buy a Canadian SVX. Our fog lights are always on without the regular lights. The are used as the mandatory daytime running lights. They only turn off when you put your regular lights on. In this case you can then manually turn them back on with the switch.
Old 02-26-2013, 12:50 AM
I am sure svxcess will explain when he sees this thread again. Good luck.
Old 02-26-2013, 04:48 AM
wdb wdb is offline
dances with roads
Or you could use HIR bulbs. More usable light, not just more blue light. Very easy to fit because they pop right into the existing housing after a bit of filing, which took me maybe 5 minutes. I got mine from rallylights.com - they mark the area that needs to be filed off so it's drop-dead easy. I've had a pair in my STi since 2005 and they're still going. I put HIRs in the low and high beams in the SVX.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 02-26-2013, 09:06 AM
kinz kinz is offline
I have the 55w ddm tuning installed. I quit using my foglights when I did the low beam hid kit since there was very little difference in lighting.
Ive been flashed once and that was right after the install when I still ran with fogs out of habit.
I believe I have a link in my signature with the thread I used for install.
I would like to learn the ways of daytime fog
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
Old 02-26-2013, 09:58 AM
+1 have been using HIRs in both of mine for about a year, and they work great. Plenty brighter, stock look, and none of the PITA or engine bay clutter of the HIDs.
